vtec girdle on ls and b20 blocks
Old Apr 9, 2005 | 07:03 AM
mrDFWmechanic's Avatar
Default vtec girdle on ls and b20 blocks
can you take the block girdle that goes over the 3 middle sections of the crankshaft from like a gsr and use that on an ls motor ?? just curious cause endyn is selling an aftermarket one and it says it can be used on any dohc motor. and they want 200 bucks for it and the oem ones only cost like 70. somebody help me out here
Old Apr 9, 2005 | 07:25 AM
i found this thread and they said that if you use a vtec girdle you have to also use the windage tray oil pinkup and oil pan from that motor as well. so if i buy this one from endyn can i just use the ls stuff then ?
here's the other thread
https://honda-tech.com/zerothread?id=1194167
here's a link to the endyn girdle
http://www.theoldone.com/components/block_girdle/
Old Apr 9, 2005 | 08:06 AM
bruthaboost's Avatar
Default Re: (iROCKtheSOHC)
You're better off just buying the stock gsr girdle and machining and doweling the mains of your stock b18a/b to accept the girdle. Should be cheaper this way.
HTH,
Jeff
Old Apr 9, 2005 | 09:27 AM
thanx that works out good because i have a friend that works at acura so he can get me a brand new girdle for cheap then. thanks for your help
BigT21
Apr 8, 2009 07:01 AM
myteggy95
Jun 28, 2008 09:45 AM
methodz55
Apr 19, 2005 08:43 PM
j87w
Feb 7, 2005 11:40 AM
Short_Shifter
Mar 25, 2002 03:29 PM
