Need help installing ignition lock assembly
My sister's car was recovered after being stolen. Luckliy it wasn't stripped, just taken for a joy ride. The thieves jammed a screwdriver into the ignition. Right now, the old ignition is out and i just bought a new ignition lock assembly so I can install it for her. Can anyone give advice or instructions on how to install it?? Thanks! It's just sitting in our garage right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo2slocivic »</TD></TR><TR><TD CLASS="quote">you will need to either drill out the break awaybolts or chisel them out then it is just a matter of bolting the new lock assy in making sure it is lined up correctly</TD></TR></TABLE>
I received the new ignition lock assembly. Looks pretty easy to connect, However, i know what you're talking about with the break awaybolts. HOW the heck do i take that out with such limited space???????? Would it work if i just drilled holes through the top of the bolts??? Do i have to use an easy-out drill bit for that/?
get a little sharp punch and a small hammer and start hitting ccw ( counter clock) those brake away bolts are really easy to remove once you loosen them up ..trust me it is not a big deal takes a little patience
Achenar
Apr 11, 2008 09:16 AM
