Cable to hydro
How much of a hassle is it to put a 1992 b17a w/ cable trans into my 1994 civic?
What axles to use?
does it bolt up with the old integra mounts?
does the 92 shift linkage work?
What about the speed sensor?
Should i buy the hasport conversin kit for the cable trans or should i convert the civic over to a cable?
What axles to use?
if you use the 91-93 teggie intermediate shaft you need the same year(s) cv axles but you can use the 94+teggie intermediate shaft and axles. I have been told by many people that you can use the 92 linkage, i have always used 94+ but if the orginal linkage is included i'd try it before you spend the money on the 94+. Advid componits and hasport both make hydro to cable conversions
Radyjr
May 12, 2006 10:50 PM
