garage sale- cleanin out the shop- manifolds, piping etcc.
1st B18c1 legit block complete with head studs and main studs and caps and LS crank just needs rods pistons and a head. and should be ready go to
FRESH BORE AND HONE 81.5MM SLEEVED heavy duty by GE 1450$ shipped - SOLD
1st gen B16 TB - 30$-- SOLD
B series log manifold upper bolts on cyl 2 and 3 need to use allen heads. which will be provided 220$ shipped brand new. t3t4 AC compabiel. includes stud kit - SOLD
D16 log manifold- either radiator hose will need to be modified- WG hits rad hose not sure if deltagate will clear.- ceramic coated 225$ shipped will provide WG block off plate if wanted includes stud kit
short B series tubular manifold- will be flanged for 38MM wg- non ac compatible
- PENDING -- SOLD
HP/STR sheet metal intake manifold- heli coiled tb stud side. may need to do slight grinding to fit TB- i just took a step bit and made mine a lil bigger. worked perfect. dynoed 400 WHP with this . also ported the runners for smoother flow. 200$ shipped
honda CBR 954 individual throttle bodies with injectors good condition with B16 runners weldedand ported - Pending- SOLD
MISC downpipes
i used this on my B series 4 bolt AC compatible FR style manifold 100$ shipped i tried to close loop it but it hit the oil pan cuz i forgot about te deeper GSR sump. has 2.5 flex pipe. used for 30 miles- bad injector melted cylinder so i took the setup off.
shorty dp imade for a D series log compressor on driverside -SOLD
DP made for 2.5 AC D series log- coudlnt get one of the bolts in 50$ shipped -- SOLD
MISC charge pipes
2.25 s2k upper ic piping flanged for HKS SSQV off revhard kit 30$
2.5GSR upper charge pipe no bov flange 50$ 60$ and itll be flanged for greddy bov - SOLD
used for 20 miles. doesnt come with coupler
2.25 GSR fmic piping . lower pipes are new but i made them a while ago. upper charge pipe is used. great fitment with 6" CCA intercooler or new JRC 6 inch version i can make you teh last pipe to complete it 150$ shipped 15$ and ill make the turbo to the other IC pipe. and 10$ more ill flange for greddy bov.
someone tryin to make a header ?> mild steel 2 inch with 2.5 opening collector
PORTED 45$ shipped
original greddy profec
complete just missing the bracket to bolt up the unit to the car comes with all sensors and control unit. 110$ shipped - SOLD
bought it to evaluate ssautocromes new manifolds. manifold is thicker.
ill sell it for 325$ shipped. and it will be braced with Stainless flat bar tig welded. -- PENDING -- SOLD
if interested PM me or email me at spoolindevelopment@gmail.com
prices are OBO.
Modified by project dc2 at 7:13 AM 4/18/2005
Modified by project dc2 at 7:00 AM 5/5/2005
Modified by project dc2 at 11:38 PM 5/9/2005
- PENDING -- SOLD
MISC downpipes
MISC charge pipes
PORTED 45$ shipped
prices are OBO.
