New setup: disappointing E.T, Stoked on the MPH
Old Apr 8, 2005 | 07:48 PM
hondaguyef's Avatar
Default New setup: disappointing E.T, Stoked on the MPH
EDIT: Update(s) on pages 2&3. Better E.T.(still slow) and MPH
1992 Si hatch(full street trim) 2530lbs. w/ driver
B18c1 block(81.5mm), LS crank, JE pistons, Eagle rods, B16 head, GSR cams, ITR IM, Garrett To4e .80/.70(the lag monster/launch killer) @ 8-9 psi on these runs, Rev hard cast T4 mani, Conservative street tune.
Runs:
60' 2.093 2.276 2.099
1/8 8.410 8.65 8.618
1/4 12.71 12.95 12.95
MPH 115.83 115.24 114.63
Runs were made on M/T 24.5x7x13 slicks on Bogarts. The first run was made w/ 13 psi in the slicks and it bogged hard off the line (Preloaded @ 5500). The 2nd and 3rd run were made w/ the slicks at 14psi. 2nd run preloaded @ 7000 and spun then hooked and bogged. 3rd run preloaded @ 6500 and still bogging. Looks like I'll be going back to 22's for a while. I'm happy w/ the MPH considering the weight of the car but, the 60's and E/T's are garbage. Feedback welcome. Thanks
Phil
Modified by hondaguyef at 12:54 AM 4/9/2005
Modified by hondaguyef at 8:22 PM 4/17/2005
Modified by hondaguyef at 6:33 PM 4/24/2005
Old Apr 8, 2005 | 07:54 PM
b19coupe's Avatar
Default Re: New setup: disappointing E.T, Stoked on the MPH (hondaguyef)
Try launching higher
Old Apr 8, 2005 | 07:56 PM
hondaguyef's Avatar
Old Apr 8, 2005 | 08:06 PM
Blown90hatcH's Avatar
Drop the tire pressure down to around 6-8 cold and launch at 7k again. Just gonna take some testing and seat time homie. Looks good though man.
Old Apr 8, 2005 | 08:46 PM
turtle-eg's Avatar
I think you should just keep the 24.5s.... try lauching higher to help with the bogging... Are you using a two step at the line to build boost?
Old Apr 8, 2005 | 08:53 PM
hondaguyef's Avatar
Default Re: New setup: disappointing E.T, Stoked on the MPH (turtle-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg &raquo;</TD></TR><TR><TD CLASS="quote">I think you should just keep the 24.5s.... try lauching higher to help with the bogging... Are you using a two step at the line to build boost?</TD></TR></TABLE>
I don't want to launch much higher than 7K w/ the 24.5's. I wasn't using the 2step but, even if I was it doesn't build boost (UD fuel cut style not soft touch). It will be used next time out though.
Phil
Old Apr 9, 2005 | 03:26 AM
slambedcivic's Avatar
if yodue like, you can use my 22s.
Old Apr 9, 2005 | 04:20 AM
nsxmatt's Avatar
Those 24's are tricky. With your power though you'll want to go back to the 24's. I'd personally air them up more and make the run so you can spin them no matter what. then slowly drop the pressure and as they start to bog launch higher. With that big turbo i'm afraid your going to have to launch it pretty high.
Good luck man, get those 11's
Old Apr 9, 2005 | 07:16 AM
beerbongskickass's Avatar
Default Re: (nsxmatt)
Last time I was at the track I had my tire pressure at 10psi on 23x8x13 slicks and I was launcing off the rev limiter (7300 rpms) and my car was hooking extremely well. The higher I launched the better my 60ft and 1/4 miles times got. My last and best run I pulled a 1.7 60ft and 12.6, but only trapped 107 mph since I'm not making much horsepower. I'd suggest launching as high as you can.
Old Apr 9, 2005 | 07:27 AM
hondaguyef's Avatar
Default Re: (beerbongskickass)
Thanks for all of the comments and suggestions. I may set the 2 step the next time out @ 7K play w/ the pressure and see what happens.
Jason,
I'll definatley have to get some runs on your 22's. It seems like most of us around here have the best luck w/ them. Rob: 11.52, Tommy 11.60, Josh 11.5x, Donny 12.8's, Me: 12.40's, you 12.70's. They must be working.
Phil
Old Apr 9, 2005 | 08:33 AM
Default Re: (hondaguyef)
just let me know, im not headed to the track any time soon.
Old Apr 9, 2005 | 09:22 AM
deftones0817's Avatar
Default Re: (slambedcivic)
Could be alot of things I wouldnt get rid of those 24.5 i know your going to need them. I'm sorta shocked to be honest. I'm not using uberdatas 2 step right now I'm learning where to launch the 24.5. I think a few more practice runs and you'll figure out where you need to be at. You cars a whole nother beast than mine so I don't really have any good advice. The mph is there though. Good luck man. See ya at track.
Old Apr 9, 2005 | 03:19 PM
hondaguyef's Avatar
Default Re: (deftones0817)
Josh, Definatley gonna keep the 24.5's. Those pases were made on 8-9 psi but, I want to see if I can get into the 11's at this weight and Power output(On 22's) first then the boost will go up and the 24.5's will be utilized. Thanks for the comments. Good luck in Power Street
Phil
Old Apr 9, 2005 | 03:31 PM
HybridRacer69's Avatar
just went for a ride in the car and damn it's fast you know 11's are on the way
Red
Old Apr 10, 2005 | 03:54 AM
dome's Avatar
7500 off the line
Old Apr 10, 2005 | 04:09 AM
hondaguyef's Avatar
Default Re: New setup: disappointing E.T, Stoked on the MPH (dome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dome &raquo;</TD></TR><TR><TD CLASS="quote">7500 off the line</TD></TR></TABLE>
Might have to.
Old Apr 10, 2005 | 02:20 PM
Rev limit off the line.
Old Apr 10, 2005 | 05:33 PM
dester223's Avatar
UD's 2 step really doesn't built too much boost.
I think with Crome (Same fuel cut for launch control) I was able to biuld 2 to 3 pounds MAX @ 6,000 rpms.
That's why I bought the MSD digital 6, HVC coil and used the MSD's 2 step + some timing retard for my launch control.
Nice MPH though I wonder if my 4 door is about the same weight as your si hatch.
Old Apr 10, 2005 | 05:50 PM
97hb's Avatar
Nice MPH I remember when we were both 110 traps
Old Apr 10, 2005 | 07:44 PM
hondaguyef's Avatar
Default Re: New setup: disappointing E.T, Stoked on the MPH (dester223)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dester223 &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks and I was looking at the weight specs earlier and your 4 door is lighter than my hatch . That sucks but I work w/ what I have. The weight will be dropping soon though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb &raquo;</TD></TR><TR><TD CLASS="quote">Nice MPH I remember when we were both 110 traps </TD></TR></TABLE>
Thanks. Wasn't too long ago for me(110 MPH). Too bad @ 110 I was going 12.40 and now I'm nearing 13 sec. at over 115 . I'm going to run her on the 22's and see what it'll do. I have a feeling that the first pass on the 22's will be an 11 sec. run @ 115 or so. I will definately practice on the 24.5's but, I want to see what will happen and at what RPM I will cross the line on the 22's. Updates coming soon so stay tuned.
Phil
Old Apr 10, 2005 | 08:23 PM
nsxmatt's Avatar
On 22's you'll shift into 5th before the finish
Old Apr 10, 2005 | 08:53 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">On 22's you'll shift into 5th before the finish </TD></TR></TABLE>
Gear speed calc.(GSR trans) showed that I'll be at 121MPH. @ 8400 (where I have my rev limiter). I can raise it if needed
Phil
Old Apr 10, 2005 | 09:02 PM
yeah i was shifting into 5th
Old Apr 10, 2005 | 09:52 PM
Jockobo's Avatar
good luck on 11s...should be there easy
Old Apr 10, 2005 | 10:00 PM
dester223's Avatar
This man speaks the truth.
on my 111 mph pass. I bounced off the rev limitor probably just a TAD before the finish. I'd hear/feel the rev limitor kick on, and the win light would flash (well, not always, but you get the point)
I don't know about you guys, but I hate trying to hit 5th gear when racing. Always seem to mess it up somehow.
Oh yes, on the weight, I looked it up too. http://www.clubcivic.com/board/specs.php
I suppose 2245 for a 4 door LX and 2270 for the SI hatch. Man, I wanna actually go weight my car
Got any pictures of your setup?
