Anyone wanto to critique my DPFI to MPFI conversion..
Old Apr 8, 2005 | 07:00 PM
No-Gi's Avatar
Default Anyone wanto to critique my DPFI to MPFI conversion..
After much research I decided to go ahead and convert my harness to MPFI. I recently purchased a 91 DX HB and messed up the engine the first time out (drove it 30 miles w/o water). I knew I was going to do a swap soon(d16z6 or y8) so I drove till it died. Today I got a great deal on a Z6 (complete with P28, tranny which I cant used,dizzy..) for $300.00 so I picked it up. A budy of mine came through with an OBD-I H22 harness which he let me chop up to do what I needed. It was a bit more difficult using this harness because the H22 uses a resistor box and I don't plan on using one since I have the injectors that came with the motor.
Here are some pics, but I am not done yet. I still have to go back and fix some of the soldering and wrapping. Also, I still need to run C1,C2 and A3,A7 to the engine bay as well as extended the coolant plug. Please let me know if the wiring is correct.
Here is the Yelow DX to Brown and Red DX to Blue. Also note the 2 yell/Blk soldered.
I ran all the red/blk to the end plug since I will not be using the resistor box as well as the 2 yel/blk fro the Dx harness.
I extended and switched the TPS and extended the EACV (little long but better than short)
The coolant one which has not been done because I dont know where each wire should go. Any ideas?
Any comments? ideas? miss anything?
Thanks in advance.
Old Apr 8, 2005 | 07:07 PM
Magick211's Avatar
Default Re: Anyone wanto to critique my DPFI to MPFI conversion.. (3_South)
Not bad but i would use heat shrink
Old Apr 8, 2005 | 07:18 PM
No-Gi's Avatar
Default Re: Anyone wanto to critique my DPFI to MPFI conversion.. (Magick211)
funny think is I have some but forgot to use it. Maybe I will redo it tomorrow.
Old Apr 8, 2005 | 07:26 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3_South &raquo;</TD></TR><TR><TD CLASS="quote">funny think is I have some but forgot to use it. Maybe I will redo it tomorrow.</TD></TR></TABLE>
haha i did the same thing last time i soldered. Looks good.
The coolant wires are grn/whi and red/whi. Should be located in the 14 wire plug on the passenger shock tower.
Old Apr 8, 2005 | 11:48 PM
civickiller's Avatar
Default Re: Anyone wanto to critique my DPFI to MPFI conversion.. (eda6)
looks like ****, get it covered
Old Apr 9, 2005 | 04:12 AM
No-Gi's Avatar
Default Re: Anyone wanto to critique my DPFI to MPFI conversion.. (civickiller)
thank you genius.
Old Apr 9, 2005 | 08:22 AM
crxtreme89h's Avatar
Looks like you just dripped hot solder on the wires. Did you heat the wires up and let the wires heat absorb the solder? Other than that, it looks good to me. You could just use 3m soft electrical tape and loom it.
Old Apr 9, 2005 | 09:14 AM
No-Gi's Avatar
Default Re: Anyone wanto to critique my DPFI to MPFI conversion.. (crxtreme89h)
I started to let it drip but then corrected them by heating the wires and came out much better. I also noticed that I extended the AIT plug rather than the EACV. io will have to fix that one as well.
Old Apr 9, 2005 | 10:43 AM
Rywire's Avatar
Thats a very common mistake, the iat is the red and grn wires. I remember it by the "christmas colors" always leave them alone...
Yes, heatshrink is needed for sure.
The fan switch needs to be relocated to the thermostat housing. You can use any round 2pin plug for this. I use the tandem valve plug because it is not needed anyway, and needs to be removed from the harness. Polarity dosent matter when wiring this sensor.
Your wiring is correct other than that...
Old Apr 9, 2005 | 03:47 PM
No-Gi's Avatar
Default Re: Anyone wanto to critique my DPFI to MPFI conversion.. (droppedcrxsi)
Thank to all.
Old Apr 9, 2005 | 04:09 PM
Ass$nyper's Avatar
Pirate General...YARRRR
if it runs its good enough
once cleaned up a bit will be nice not bad now
Old Apr 9, 2005 | 08:21 PM
daidilus's Avatar
look good....but i would just use OBD1 injectors and forget the resistor box.....
Old Apr 9, 2005 | 08:58 PM
JDMCivicEF9's Avatar
Hey looks pretty clean to me. Not to bad for a first timer (if you are), but always use heat shrink.
Old Apr 9, 2005 | 09:47 PM
Rywire's Avatar
Default Re: (daidilus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">look good....but i would just use OBD1 injectors and forget the resistor box.....</TD></TR></TABLE>
Thats what he has done
Old Apr 10, 2005 | 08:54 AM
daidilus's Avatar
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Thats what he has done</TD></TR></TABLE>
opps alcohol is bad for you
Old Apr 10, 2005 | 11:10 PM
Rywire's Avatar
HAHAHAHAH
Old Apr 10, 2005 | 11:20 PM
RCautoworks's Avatar
The wiring looks a little shoddy but if your happy with it
sinneD
Sep 13, 2005 11:18 AM
Jstue
12
Nov 20, 2003 08:10 PM
Jstue
Nov 19, 2003 01:07 PM
fwpguy
Oct 9, 2003 06:27 AM
