I NEED HELP!!! CAN YOU MIX MATCH VALVE TRAIN?
Old Apr 8, 2005 | 05:49 PM
ek2k's Avatar
Default I NEED HELP!!! CAN YOU MIX MATCH VALVE TRAIN?
So i have Jun Valvetrain, but one of my homies lost one spring so basiclly i need one. i am running a crvtec mild built with some s2s2 cams and i know the jun will be cool to run but where could i get a dual valve spring? i called skunk2 and they went ahead and sent me one dual spring still waiting on it, but my true question is....Is it cool to run that just one dual spring with my jun retainers and jun springs with those cams because i know that diff springs have different rates????? please help will i be ok and not worry soo much???
Old Apr 8, 2005 | 05:54 PM
ek2k's Avatar
Default Re: I NEED HELP!!! CAN YOU MIX MATCH VALVE TRAIN? (ek2k)
bump cause i wanna know....
Old Apr 8, 2005 | 06:09 PM
ek2k's Avatar
fv yjrvyik,hkl.
Old Apr 8, 2005 | 07:53 PM
ek2k's Avatar
SOMEONE
Old Apr 11, 2005 | 06:04 AM
ek2k's Avatar
anyone??
Old Apr 11, 2005 | 09:17 AM
turbociv's Avatar
I wouldnt do it do to different harmonics that the matched set of springs would make. The fact that 1 valve will be closeing/ openeing at different speeds/rates might cause some funny harmonics which could possibly break a cam.
Old Apr 11, 2005 | 11:12 AM
ek2k's Avatar
Default Re: (turbociv)
thanks bro thats what i needed to hear i am going to go buy today my set of supertech valvesprings or portflow but i heard more good things of supertech. thanks alot..
Old Apr 11, 2005 | 02:53 PM
thevanitygroup's Avatar
Default Re: (ek2k)
Which spring do you need? Inner / Outer? If its an outer I say get a set of Type R springs for the outside and run the Jun inners.
HATCHIN238
Aug 20, 2010 11:56 AM
Rene M
Mar 24, 2006 05:26 AM
uc0083
Jan 7, 2006 11:23 PM
jrcrx
May 30, 2002 06:46 PM
chasrex
Apr 13, 2002 01:33 PM
