Need map sensor help.
Old Apr 8, 2005 | 05:44 PM
ItsStockOfficer's Avatar
Default Need map sensor help.
Hey guys. I have a turbo Miata, and use an AFC for fuel comtrol. I am going to be using a Honda mapsensor for the TPS signal and was curious if anyone knew which wire was which. Staring at it from the nipple side it has white wire, a green wire with a white stripe and then a yellow wire with a red stripe.
It is physically idential to this sensor.... so i suppose if anyone has a wiring diagram online for an 88-91 civic/crx I would be doing awesome as well!
http://cgi.ebay.com/ebaymotors...=WDVW
TIA
Sean
Old Apr 8, 2005 | 08:27 PM
hondaguyef's Avatar
Default Re: Need map sensor help. (ItsStockOfficer)
Green White= Ground
White= MAP signal
Yellow/red= 5V
Phil
B18EG6
Mar 28, 2007 12:36 PM
B!^A@
Nov 23, 2006 12:13 PM
ProjectLudeSiR
Nov 9, 2003 10:03 PM
xXx Justin xXx
Jun 18, 2003 09:49 AM
vtectuner99
Aug 30, 2002 12:34 AM
