5TH GEN BREAKS
Old Apr 8, 2005 | 04:50 PM
RUBZERK's Avatar
Default 5TH GEN BREAKS
the car = 95 accord lx 4 door with abs. FRONT & REAR DISC
the problem = as I press the break pedal, it tends to go to the floor & just slow down the car, but not really. If I pump the break pedal 2 times it works fine.
The reservoir under the hood is full.
What can be the problem ???
What should I look for ???
Modified by RUBZERK at 10:18 AM 4/9/2005
Old Apr 8, 2005 | 05:27 PM
sj993's Avatar
Default Re: 5TH GEN BREAKS (RUBZERK)
Brake fluid dirty maybe? If so, try flushing it. When did you last change the brake pads?
Old Apr 8, 2005 | 05:56 PM
hometheaterman's Avatar
Default Re: 5TH GEN BREAKS (sj993)
Air in the lines? When was the last time you bled them?
Old Apr 8, 2005 | 06:55 PM
RUBZERK's Avatar
Default Re: 5TH GEN BREAKS (hometheaterman)
bought the car in 04 & havnt changed the breaks
Old Apr 8, 2005 | 08:04 PM
sinister2c's Avatar
master cylinder is done...buy a new one its like $80 plus core at any autoparts.
Old Apr 8, 2005 | 09:05 PM
RUBZERK's Avatar
Default Re: 5TH GEN BREAKS (sinister2c)
How can i check to be sure that that is the problem ???
Old Apr 8, 2005 | 10:01 PM
ForceXVII's Avatar
Your drum is out of round. Change it asap!!
Old Apr 8, 2005 | 10:04 PM
ForceXVII's Avatar
the only time to change the master cylinder is when you see blackish fluid which cause by defected rubber seal.
Old Apr 8, 2005 | 10:50 PM
deserthonda's Avatar
you need a brake master cylinder , no out of round drums if the pedal sinks to floor while you brake you have an internal leak in brake master the inner seals are worn and cannot hold pressure replace it asap
Old Apr 8, 2005 | 10:55 PM
solo2slocivic's Avatar
master cyl test, at a stop pump the pedal and hold it, if it begins to fall you either have leak or the master is bad. but i believe your rear brakes are not adjusted correctly, to check set your parking brake and then step on the brake pedal if it feels firmmer and higher without pumping that is your problem.
Old Apr 8, 2005 | 11:00 PM
honda_kid42's Avatar
master cylinder......had the same problem one time......
Old Apr 9, 2005 | 01:02 AM
iand415's Avatar
Default Re: 5TH GEN BREAKS (ForceXVII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceXVII &raquo;</TD></TR><TR><TD CLASS="quote">Your drum is out of round. Change it asap!!</TD></TR></TABLE>
lol
back to the topic... its most likely your primary or secondary cups in your master cylinder. take sinister2c's advice and buy a new master cylinder.
Old Apr 9, 2005 | 02:29 AM
The_Todd's Avatar
Farts in the shower
Default Re: 5TH GEN BREAKS (iand415)
Master cylinder....easy to replace but make sure to bleed your brakes after installing the new one .
Old Apr 9, 2005 | 08:53 PM
RUBZERK's Avatar
Default Re: 5TH GEN BREAKS (.ken)
How do i test it to be 100% so I dont blow $100 relpacing it ???
Old Apr 9, 2005 | 08:59 PM
The_Todd's Avatar
Farts in the shower
If you pedal goes all the way to the ground and you have already bled the brake system then it is without a doubt your MC.
NTM if you replace it and it still does it just take the part back .
Old Apr 9, 2005 | 09:34 PM
RUBZERK's Avatar
Would it be possable that my break pads need changed ?
Old Apr 9, 2005 | 09:51 PM
read all the posts.... master test
it is possible you have a caliper problem that is compensated for when you pump the brake pedal a couple of times
take the wheels off and inspect everything, look up under the dash where the master cylinder push rod hooks to the brake pedal, is ther brake fluid around the gommet?
Old Apr 9, 2005 | 10:01 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">Would it be possable that my break pads need changed ?</TD></TR></TABLE>
Typically no, it's your MC bro .
Old Apr 11, 2005 | 02:48 PM
RUBZERK's Avatar
Is this the only part i need to replace ???
Old Apr 11, 2005 | 07:15 PM
RUBZERK's Avatar
TTT
Old Apr 11, 2005 | 07:56 PM
markyh's Avatar
It's brakes, not breaks. WTF?
Old Apr 11, 2005 | 08:11 PM
Default Re: 5TH GEN BREAKS (markyh)
its blown seals in the MC....have had the same problem more than once!!!!!!
Old Apr 11, 2005 | 08:29 PM
Stoich EG2's Avatar
Default Re: 5TH GEN BREAKS (honda_kid42)
that pic is of the master cylinder, yes. READ ALL THE POSTS ON HOW TO CHECK... doesn't seem like you're reading them....
Old Apr 11, 2005 | 11:33 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">Is this the only part i need to replace ???
Yes...and some of this:
to remove your brake fluid from your old MC reservoir.
And some of this:
and one of these:
They are special wrenches that won't strip your brake lines that run into your MC.
dylokjai
Dec 30, 2006 09:39 PM
s10cky
17
Dec 20, 2006 07:19 PM
PatrickGSR94
Apr 29, 2004 10:02 PM
MrEg
Sep 22, 2003 04:49 PM
GSR95T
Sep 4, 2002 09:21 AM
