Tighten Timing belt Question!
Old Apr 8, 2005 | 01:33 PM
blackek00's Avatar
Default Tighten Timing belt Question!
ok i have a gsr my timing belt is kinda loose. I want it to be tight .my question is
if i loosen up then tensinor bolt and then turn the crank pulley ccw until it pass 3 tooth on the cam gear then tighten it up. wouldnt my tdc move or not be lineing up right.? or do i just go with the coat hanger thcnique and pull up the tensinor spring ?..
Old Apr 11, 2005 | 03:35 AM
JimBlake's Avatar
Default Re: Tighten Timing belt Question! (blackek00)
Loosen the tensioner bolt, then as you turn a little bit (CCW) just watch to be sure it doesn't skip a tooth. What you're doing is pulling the exhaust side of the belt tight, moving the slack over where the tensioner can take it up. I've found it works better if you hold a little tension with the crank pulley, while you tighten the tensioner.
If you have to use the coathanger method, make sure you don't pull too hard. The belt isn't supposed to be as tight as, say, your A/C belt.
Old Apr 11, 2005 | 07:29 PM
PupaScoopa's Avatar
Default Re: Tighten Timing belt Question! (JimBlake)
The tensioner is designed to get "just right" as you torque it down after taking up all the slack on the other side of the crank (from the crank to the exhaust cam).
Deviant117
Mar 28, 2011 09:23 AM
god.loves.ugly
Jan 18, 2007 03:44 PM
an2ny888
Feb 17, 2006 04:57 PM
vtec69
Jan 16, 2003 10:28 AM
jwwskatr
Nov 14, 2002 08:01 PM
