My TypeR is popping out of 5th gear.....
Old Apr 8, 2005 | 01:13 PM
GrlRcr4's Avatar
Default My TypeR is popping out of 5th gear.....
Does anyone know what this could be? My car is only popping out of 5th gear, could it be my synchros?
Old Apr 8, 2005 | 01:36 PM
Bbasso's Avatar
Default Re: My TypeR is popping out of 5th gear..... (GrlRcr4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Welcome to HT...
Sounds like you have syncro problems.
You will need to open the tranny and see
Enjoy your stay </TD></TR></TABLE>
Old Apr 8, 2005 | 01:38 PM
GrlRcr4's Avatar
I was hoping that it wasn't the synchros...do you think it could be the bushings in the linkage?
Old Apr 8, 2005 | 01:40 PM
Opie's Avatar
The best noises are yet to come.
Old Apr 8, 2005 | 04:45 PM
BlueIntegraBoy's Avatar
GrlRcr4, did you buy Scotty's old Type-R? The 01 with 24k? I so wanted to buy it.
I've been keeping count of all the ITRs on the Big Island. For a small population, there are a lot. I see an ITR almost everyday.
Old Apr 8, 2005 | 05:00 PM
1Quikgsr's Avatar
Default Re: My TypeR is popping out of 5th gear..... (Bbasso)
tranny problems synchros more then likely
Old Apr 8, 2005 | 05:21 PM
Finland's Avatar
Default Re: My TypeR is popping out of 5th gear..... (1Quikgsr)
Mine had the same problem....here's how I fixed it
Old Apr 8, 2005 | 06:23 PM
92TypeR's Avatar
FSAE
Default Re: My TypeR is popping out of 5th gear..... (Boondock Saint)
Have you tried flushing your tranny fluid? Fifth gear is the highest on the set inside the housing, so it is the first to be 'dry' when low on MTF.
Old Apr 8, 2005 | 06:25 PM
Finland's Avatar
Default Re: My TypeR is popping out of 5th gear..... (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried flushing your tranny fluid? Fifth gear is the highest on the set inside the housing, so it is the first to be 'dry' when low on MTF. </TD></TR></TABLE>
I agree, try it, didn't work for me but worth a shot.
Old Apr 9, 2005 | 11:02 AM
GrlRcr4's Avatar
Blue Integra Boy: No I didn't buy scotty's TypeR...I ordered mine about 6 months ago from HMO.
Thanks for the advice...I will try flushing the tranny fluid.
Old Apr 9, 2005 | 11:07 AM
B2FiNiTY's Avatar
Default Re: (GrlRcr4)
Try changing the fluid and making sure the car is level when you add fluid.
Old Apr 9, 2005 | 11:16 AM
JMcDB18C's Avatar
Mine was popping out of fifth for a while, thought was synchros but i just need fluid
Old Apr 9, 2005 | 11:41 AM
s2kdre's Avatar
Default Re: (JMcDB18C)
try synchromesh or open up the tranny.
Old Apr 9, 2005 | 11:43 AM
Erik B's Avatar
my 5th gear synchro went out on me...it never poped out tho...just grinded going into gear at like anything over 2.5 to 3k rpms. you running a short shifter?
Old Apr 9, 2005 | 01:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrlRcr4 &raquo;</TD></TR><TR><TD CLASS="quote">Blue Integra Boy: No I didn't buy scotty's TypeR...I ordered mine about 6 months ago from HMO.
Thanks for the advice...I will try flushing the tranny fluid.</TD></TR></TABLE>
Oh I thought you bought a Type-R. What car is the B18C in? A Civic?
Old Apr 12, 2005 | 08:53 PM
GrlRcr4's Avatar
BlueIntegraBoy...I do have a TypeR in my civic...why do u know which car is mine?
Erik B....I have the stock shifter
I am going to flush out the fluid in a day or so....when I have a brake from work. (I am praying that is the problem). Thanx!!
Old Apr 12, 2005 | 11:13 PM
ssmdc2's Avatar
I wouldn't jump to conclusions on synchros. I would check out the detent ball springs. They are probably pretty cheap and you can easily change them without dropping the trans out of the car.
Old Apr 13, 2005 | 04:22 AM
Phoenix_ITR's Avatar
could also possibly be a tweaked shift fork.
Old Apr 13, 2005 | 05:36 AM
MADEinJAPAN's Avatar
Default Re: (delinquent)
1st step would be to top off the tranny fluid
Old Apr 16, 2005 | 12:46 PM
GrlRcr4's Avatar
Okay...well I found out I have a slow leak somewhere....We drained the tranny fluid and there wasn't very much fluid in there...I used the synchromesh and it hasn't done it since! Now I just need to fix the leak. Thanx for all the advise!
Old Apr 16, 2005 | 12:51 PM
92TypeR's Avatar
FSAE
Its great when the easiest/cheapest solution is the right one
Old Apr 16, 2005 | 01:51 PM
Opie's Avatar
Old Apr 16, 2005 | 02:51 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: (opie)
on a quick fix, check ur axle seals for the slow leak yo
brandon5391
Jan 28, 2008 05:19 PM
TypeAhhh
Aug 4, 2005 03:09 AM
emissionsux
Nov 23, 2004 07:18 AM
Surfer_Sandman
Nov 17, 2004 05:43 PM
HatchBox
15
Dec 19, 2003 09:12 PM
