H22A4: Weird startup idling and shutdown problem, need input
Old Apr 8, 2005 | 12:01 PM
CXHATCHver2.2's Avatar
Default H22A4: Weird startup idling and shutdown problem, need input
This started the last couple days, It is an '99 H22A4 and when i start my car (cold start) it takes a much longer time then normal to kick over or it tries to and then dies. once it does get going it idle surges until it starts heating up.
Once it gets running and warmed up it runs perfectly fine, now when i turn the car off there is a whining sound like a vacuum leak but its really elongated and kinda sounds like a valve or something closing. Also sounds like its maybe underneath...??
I've checked for all the normal leak spots and whatnot and found nothing, now would a faulty fuel pump make this noise? I know it would give me shitty starts like this but the noise is whats killin' me here, cant figure it out.....Any input would be appreciated guys
Old Apr 8, 2005 | 05:26 PM
Default Re: H22A4: Weird startup idling and shutdown problem, need input (CXHATCHver2.2)
nothing guys?.......maybe ill just kick it
Old Apr 8, 2005 | 05:28 PM
dmxsoulja3's Avatar
fast idle thermal valve most likely, get a helms manual for a lude so you can work on the h22
Old Apr 8, 2005 | 10:43 PM
PrettyLude's Avatar
i would think that his idle problem is dealing with the iacv, he said its fine when it warms up
5Point7Liter
Aug 20, 2008 12:39 AM
sikluder
Jun 29, 2006 05:44 PM
uneek4dr
Feb 6, 2006 01:28 PM
DrewDown
Jan 1, 2005 03:45 PM
Spoonie Luv
Oct 2, 2003 01:48 PM
