Cant figure out whats wrong?????
Old Apr 8, 2005 | 10:10 AM
lude_type_s's Avatar
Default Cant figure out whats wrong?????
even the mechanics at honda cant find anything wrong. my car have fuel, spark, air, and compression. yet it just cranks and cranks. doesn't fire up. gas is good, checked that. new dist and coil tried. new computer tried. new plugs tried. new ignition switch tried. no check engine lights and diagnostic computer isnt picking anything up. was driving one night in fifth gear, gave it gas up a hill, then nothing. the engine just stut off. pulled over and it just kept cranking. if anyone can figure this one out, i'd really appreciate it. even the techs at honda are stumped. thanx. BTW it is a 97 Type SH, minus the ATTS, plus JDM H22a, plus Limited Slip.
Old Apr 8, 2005 | 10:30 AM
IHateJDM's Avatar
Default Re: Cant figure out whats wrong????? (lude_type_s)
you said you have fuel, spark, air, and compression, but what about timing? could your belt have skipped a couple teeth?
Old Apr 8, 2005 | 10:38 AM
accord-lude's Avatar
Default Re: Cant figure out whats wrong????? (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">you said you have fuel, spark, air, and compression, but what about timing? could your belt have skipped a couple teeth?</TD></TR></TABLE>
Im with IHateJDM, check your timing.
Old Apr 8, 2005 | 11:08 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Cant figure out whats wrong????? (accord-lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-lude &raquo;</TD></TR><TR><TD CLASS="quote">
Im with IHateJDM, check your timing.</TD></TR></TABLE>
Old Apr 8, 2005 | 11:34 AM
prelude1897's Avatar
Default Re: Cant figure out whats wrong????? (cb7-R)
recheck your wiring harness and make sure you have everything plugged up...Also, in the motor wire harness, there are 2 plugs that send signals back through your motor. If you get under your car, it'll sit close to your header piping near where the O2 sensor connects. I can't remember exactly where the other one is. Also, what ECU are you using?
Old Apr 8, 2005 | 11:35 AM
Default Re: Cant figure out whats wrong????? (prelude1897)
Maybe instead of taking it to Honda, take it to a little Honda performance shop. They can usually figure stuff out the dealership can't
Old Apr 8, 2005 | 11:49 AM
92hondalude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe instead of taking it to Honda, take it to a little Honda performance shop. They can usually figure stuff out the dealership can't</TD></TR></TABLE>
and its cheaper
Old Apr 8, 2005 | 01:42 PM
timing is dead on. not that either.
Old Apr 8, 2005 | 01:55 PM
v4lu3s's Avatar
RTFM
so you guys pulled the covers on the timing belt and lined up all the marks or you just tried to put a timing light on it?
Old Apr 8, 2005 | 02:14 PM
4.6LJeepXJ's Avatar
Default Re: (v4lu3s)
Check BASE timing, not ignition....
you probably blew your tensioner.
Old Apr 8, 2005 | 06:30 PM
the_nautilus's Avatar
also, have you checked your fuel pressure? 15psi will spray you but good, but it won't run the injectors properly... I recently found this one out the hard way. My fuel pump was going out, but not completely gone.
I don't see how the base timing could be off if the car just suddenly stopped working while driving. My guess is a wiring issue. No CEL's?
Old Apr 9, 2005 | 02:53 PM
4.6LJeepXJ's Avatar
Default Re: (the_nautilus)
Um if the tensioner dies and the timing belt has too much slack then the timing can either jump a tooth or 2 or can come completely off. Thus base timing would be off. Saw a 2.2SOHC with a destroyed tensioner the other day no valve damage new t belt and tensioner and the car ran mint. And then theres always the other option....bent valves....
Not saying that any of this happened to you but its a possibility.
Old Apr 9, 2005 | 05:13 PM
MackDad's Avatar
Default Re: (4.6LJeepXJ)
Pull the plugs after a quick cranking and see if they are wet. Make sure the firing order is correct as well...Did the tech's do a compression test? Or are they just going by ear? Check and make sure all the ECU grounds are intact and in the proper arrangement and condition...
Also, can you hear the fuel pump priming when you turn the key to the accessory position?
Also, after all this cranking and diagnosing, check your oil and make sure there is no gasoline in it. If there is, you will be back to where you started when you do get it running, but a little more expensive this time..
Old Apr 9, 2005 | 11:30 PM
luderacer_92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackDad &raquo;</TD></TR><TR><TD CLASS="quote">Pull the plugs after a quick cranking and see if they are wet. Make sure the firing order is correct as well...Did the tech's do a compression test? Or are they just going by ear? Check and make sure all the ECU grounds are intact and in the proper arrangement and condition...
Also, after all this cranking and diagnosing, check your oil and make sure there is no gasoline in it. If there is, you will be back to where you started when you do get it running, but a little more expensive this time.. </TD></TR></TABLE>
i agree try this and see what your results are.... to see if you are getting fuel into the compression chamber try to flood the engine once and see if your plugs are wet (they should be)....
Old Apr 10, 2005 | 12:44 PM
Mykizism's Avatar
i bet you guys 100 dollars its the freaking main relay
Old Apr 10, 2005 | 12:49 PM
Shakes's Avatar
space cadet
Default Re: (Mykizism)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">i bet you guys 100 dollars its the freaking main relay</TD></TR></TABLE>
bet its not.
the main relay is what controls the power to the fuel pump. if the main relay is shot then you will not pump any fuel. he said he has fuel so that cant be it.
pump could be giving too little gas however. if you are cranking and cranking and you dont smell gas then you arent getting enough. then go with above and swap fuel pumps.
if you can hook up a fuel gauge to the line and see where you are at. you should see about 34 - 40 psi when you prime the pump.
Old Apr 10, 2005 | 03:33 PM
Mykizism's Avatar
i guess we'll have to wait and see what the issue is, im pretty positive its the main relay or something related to it..
Modified by Mykizism at 9:20 PM 4/10/2005
Rickytiki
Apr 10, 2018 07:26 PM
drb88
Honda CR-V & Element
Aug 12, 2013 02:18 PM
Honda Ronda
Dec 31, 2009 05:38 AM
SimplyTron
Feb 19, 2007 12:08 PM
FuzzyGreen
Jan 8, 2003 07:48 PM
