is a t4 turbo a good or bad choice on a 2.2L engine
Old Apr 8, 2005 | 07:22 AM
seamoss's Avatar
Default is a t4 turbo a good or bad choice on a 2.2L engine
HI am new and in the process of building a turbo h22. I have been looking around on this site for quite some time now and finally have a question of my own.
I see many people that run boost are on t3/t4's but what about a big 2.2l engine? can I run a t4 turbo and keep the ar on the hot side real low to help spool time and run a big ar on the cold side?
Old Apr 8, 2005 | 07:32 AM
Drag_On's Avatar
You'll be fine with a larger sized T3 such as a GT series, SC series or something along those lines.
T4 is overkill for street cars for the most part - even H22s
Old Apr 8, 2005 | 08:50 AM
s2kdre's Avatar
Default Re: (Drag_On)
how much power do you wanna make? if its under 700hp then you dont need a t4.
Old Apr 8, 2005 | 08:55 AM
Lude-acris's Avatar
Default Re: (jdmhonda)
pretty much all of the prelude guys i know that have gone turbo either stick with an SC61 or T3/T04e.... You dont want a turbo that will lag, and its doubtful that your HP goals are above 400....
Old Apr 8, 2005 | 09:06 AM
seamoss's Avatar
my max whp is about 450 or so. I just here alot of people saying about cfm's are what you need to look at, so I tought with a t4 it will flow more than a t3 would. if i keep the A/R
low on the hot side won't that help spool the turbo faster?
Old Apr 8, 2005 | 09:08 AM
Honda_Tengoku's Avatar
Default Re: is a t4 turbo a good or bad choice on a 2.2L engine (seamoss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seamoss &raquo;</TD></TR><TR><TD CLASS="quote">HI am new and in the process of building a turbo h22. I have been looking around on this site for quite some time now and finally have a question of my own.
I see many people that run boost are on t3/t4's but what about a big 2.2l engine? can I run a t4 turbo and keep the ar on the hot side real low to help spool time and run a big ar on the cold side? </TD></TR></TABLE>
i agree with everyone here. I think Jason whitfields crew runs a T04E on his 725 WHP H22 hatch if that tells u anything. There is a reason why everyone chooses the SC61. Its the best of both worlds IMO and makes great power.
Old Apr 8, 2005 | 09:09 AM
turboEGhatch's Avatar
Default Re: (seamoss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seamoss &raquo;</TD></TR><TR><TD CLASS="quote">my max whp is about 450 or so. I just here alot of people saying about cfm's are what you need to look at, so I tought with a t4 it will flow more than a t3 would. if i keep the A/R
low on the hot side won't that help spool the turbo faster?</TD></TR></TABLE>
T3 frame turbos are proven to 600+ WHP. You don't need a T4 for 450 WHP.
Old Apr 8, 2005 | 10:31 AM
seamoss's Avatar
Default Re: (turboEGhatch)
bump
Old Apr 8, 2005 | 10:49 AM
Lude-acris's Avatar
SC61
Old Apr 8, 2005 | 11:31 AM
seamoss's Avatar
Default Re: (Lude-acris)
what about the sc63 I see some people on here with that turbo on there little 1.8L
Old Apr 8, 2005 | 11:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seamoss &raquo;</TD></TR><TR><TD CLASS="quote">what about the sc63 I see some people on here with that turbo on there little 1.8L
You don't need an SC63 for 450 WHP.
r1paniccia
Aug 21, 2012 05:55 PM
hondahatch741
May 30, 2005 12:36 PM
Tushner
Mar 3, 2004 09:00 AM
bearboy80
Apr 4, 2003 04:39 PM
M.A.R.C.
Jun 10, 2002 03:23 PM
