F23 Block/H22 Head [(2.3 DOHC VTEC) 56k no, no...]
Old Apr 8, 2005 | 07:02 AM
Sam1am26's Avatar
Default F23 Block/H22 Head [(2.3 DOHC VTEC) 56k no, no...]
Well I had an H23 Block with an H22 head running for a while that I was going to boost until I spun the bearings, so I've been working on this project for the last 7 months(which means it has been just sitting there half of that time)...
Here is the link to the original thread https://honda-tech.com/zerothread?id=1069869...
and here are some pics of the build and then the finished product...
My old H23 VTEC(h23a1 block/h22a1 head)...
Stock F23a1 SOHC VTEC...
Mock up of F23 block w/H22 head...
Dropping in the motor
Turbo system installed...
Here is a complete list of the setup...
F23a1 Block (86mm Bore x 97mm Stoke)
H22a1 Head (DOHC VTEC)
AEBS Head-studs
Hondata IM Gasket
FMax Log Manifold
Turbonetics T3/to4b
2.5" Downpipe (Open)
Tial 35mm Wastegate(Open Dumptube)
450 DSMs
Walbro 255lph HP Fuel Pump
Hondata S100-B
6" Intercooler
HKS SSQ BOV
Removed: PS, AC,
EGR, FITV, Butterflies,
Battery relocated to trunk...
So I tried to start er up on Wednesday and something is wrong in the tranny... I think the throwout bearing isn't aligned correctly causing it to rub against the pressure plate fingers or something... Some people have said to remove the slave cylinder and I might be able to adjust the shift fork but I don't know... Worst case scenario I have ot take the tranny back off, but no big deal... I'll do whatever it takes to get this thing running cause I'm supposed ot get it tuned next week...
Constructive criticism/advice is always welcome...
Old Apr 8, 2005 | 07:09 AM
prelittlelude's Avatar
Default Re: F23 Block/H22 Head [(2.3 DOHC VTEC) 56k no, no...] (Sam1am26)
its gonna be sick! very nice setup
Old Apr 9, 2005 | 07:37 AM
93H22ACX's Avatar
looks good. how much hp are you looking for?
Old Apr 9, 2005 | 08:11 AM
Sam1am26's Avatar
Default Re: F23 Block/H22 Head [(2.3 DOHC VTEC) 56k no, no...] (93H22ACX)
I figure the injectors will max out somewhere close to 300 whp... But with the 97mm stroke I should be looking at close to 250-275 wtq ...
Old Apr 9, 2005 | 09:04 AM
f22b2tdave's Avatar
best of luck man, id love to see the car in person sometime
Old Apr 9, 2005 | 09:58 AM
Calvinator's Avatar
Default Re: F23 Block/H22 Head [(2.3 DOHC VTEC) 56k no, no...] (f22b2tdave)
I hope you get the tranny problem fixed and get this thing running asap! we all wanna know how it runs.
Old Apr 9, 2005 | 01:33 PM
raceACCORDingly's Avatar
looks awesome. cant wait to see it tuned.
Old Apr 9, 2005 | 03:06 PM
kaoss_11's Avatar
B A N N E D
Sorry if this is a dumb question to some but never really was interested in h series til now. What benefits are you getting by putting the h duece head on the h23 block. Is it like a ls vtec type thing. Also i remember reading a post a while back about some guy doing the same thing and it seemed like alot of people doubted him. If i am talking about the same post. Also I dont really need any smart remarks just trying to learn more
Old Apr 9, 2005 | 03:25 PM
Dibble's Avatar
Are the f23 sleeves stronger? I know jack about f or Hseries. But it looks real nice and Im sure you will be puting down some real power soon. Good luck with it.
Old Apr 9, 2005 | 05:05 PM
X2BOARD's Avatar
Default Re: (Dibble)
Did you need to do any drilling or plugging like the lsvt's ?
Old Apr 9, 2005 | 06:08 PM
JDMCRX's Avatar
Default Re: (X2BOARD)
Bump
My friend wants to do the same F23 bottom and H22 head
Old Apr 9, 2005 | 09:00 PM
Silverpike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">I figure the injectors will max out somewhere close to 300 whp... But with the 97mm stroke I should be looking at close to 250-275 wtq ...</TD></TR></TABLE>
Uhh, not gonna happen Sam. 2point6 has a 98 mm stroke, and he makes around 180 wtq.
Old Apr 9, 2005 | 09:11 PM
Archidictus's Avatar
Unceasing Measure
Default Re: F23 Block/H22 Head [(2.3 DOHC VTEC) 56k no, no...] (Silverpike)
I would have taken the flexplate off and installed the manual tranny before putting the whole thing in the car, but that's just me . Good luck getting the issue all sorted out, seems like a sick project .
Old Apr 9, 2005 | 10:12 PM
Tad's Avatar
Tad
dang thats one big *** honda 4banger!!
Old Apr 10, 2005 | 04:50 AM
b_ron007's Avatar
that was NA, this is FI. F-series got plenty down low torque.
this is @8.4psi on a drag t3/t4b, AEM EMS street tuned by me, very very conservative tune, stock F23 block. he'll make 250wtq easily.
and they said it can't be done, very sweet head swap! i'd like to see how this turns out. get it together and give us a lil sample. @17psi i was @75% duty cycle on dsm 450's. 15psi by 3,700rpms
(vid)
http://www.customtints.com/Hon...i.wmv
sorry for the thread jack, i just gotta give the love to the F blocks. keep us up to date.
Modified by b_ron007 at 2:42 PM 4/10/2005
Old Apr 10, 2005 | 06:30 AM
accord387's Avatar
looking good, i want to see that thing when its running and atleast half *** tuned
And for all the questions about whats needed to put the H head on the F block, go look in all the threads that are in the prelude section.
kidna off topic is your lude sitting in the car port at hayleys (sp?) house? i might stop by one day during work. (i'm currently in windsong)
Modified by accord387 at 3:47 PM 4/10/2005
Old Apr 10, 2005 | 07:20 AM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dibble &raquo;</TD></TR><TR><TD CLASS="quote">Are the f23 sleeves stronger? I know jack about f or Hseries. But it looks real nice and Im sure you will be puting down some real power soon. Good luck with it.</TD></TR></TABLE>
Well... H-Series are made of FRM which means you can't use aftermarket pistons on the stock sleeves, but F-Series are made of Iron so aftermarket pistons drop right in(Even though I'm still using stock pistons)... Also due to the weak ring landings on the H-Series you can only run 7-8lbs of boost usually before it goes, but you see stock F-Series blocks holding up to 15lbs all day long... Plus F blocks are just cheaper and way more abundant... Most any import junkyard can get you an F22 or F23 for $150-300...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">Did you need to do any drilling or plugging like the lsvt's ? </TD></TR></TABLE>
For any F/H Block/Head combo you DO NOT need to drill or tap for the oil pressure... The Oil Control Orifice for VTEC is in every F/H block... However, if you use an F series block with an H22 head you have to PLUG TWO OIL DRAINS... If you follow the link to my thread in the first post you can see pictures of why and how you do it... One good thing to note for you non-vtec guys, If you use an H23(DOHC Non-VTEC) Head on an F series block, everything lines up perfectly and you DO NOT need to plug any drains...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverpike &raquo;</TD></TR><TR><TD CLASS="quote">
I know it would not make 250wtq with a 97mm stroke NA, but if you would have read the post or even just glanced at the pictures you would have known this motor is turbocharged...
Old Apr 10, 2005 | 07:32 AM
Sam1am26's Avatar
So I got the tranny problem worked out and she started right up... Just gonna tweak little things here and there and I'm supposed to have my dyno appointment sometime this next week...
Old Apr 10, 2005 | 10:46 AM
X2BOARD's Avatar
Wow... 200+ ft lbs of tq at THAT boost.... all in a prelude. Wow..just wow that will be a sweet highway cruiser.
Old Apr 10, 2005 | 04:05 PM
93H22ACX's Avatar
actually it will. i made 281whp and 233wtrq with a real bad dip during vtec cross over...i mean a 120whp drop because of a bad map sensor LOL....
(this was on my prelude about 2 years ago...current one will be dynoed shortly )
Good luck Sam! Keep us posted
Old Aug 14, 2006 | 12:19 AM
Honda Sport's Avatar
Well... H-Series are made of FRM which means you can't use aftermarket pistons on the stock sleeves, but F-Series are made of Iron so aftermarket pistons drop right in(Even though I'm still using stock pistons)... Also due to the weak ring landings on the H-Series you can only run 7-8lbs of boost usually before it goes, but you see stock F-Series blocks holding up to 15lbs all day long... Plus F blocks are just cheaper and way more abundant... Most any import junkyard can get you an F22 or F23 for $150-300...</TD></TR></TABLE>
actually, h22a's ringlands are breaking left and right under boost because of a bad tune. there are a few guys on here that are boosting stock h22a's with no problems with a good tune.
sounds like it's going to be a tq monster. good luck.
Old Aug 14, 2006 | 01:33 AM
exim@uu.pp121.net's Avatar
Looks nice, How much?
Old Aug 14, 2006 | 07:37 AM
Default Re: F23 Block/H22 Head [(2.3 DOHC VTEC) 56k no, no...] (Honda Sport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">
sounds like it's going to be a tq monster. good luck. </TD></TR></TABLE>
ive been boosted on stock ring lands for a while at 10-11psi, and sam had no problems with this setup, but is now is switching over the a h23 head i belive..
my original f/h build in in my sig which links to sams and Pirates wthat followed..
Old May 7, 2010 | 06:34 AM
94 accord turbo's Avatar
how do i do a h22 head and f23 block swap
Old May 7, 2010 | 06:39 AM
92cxyd's Avatar
I believe you need to search w/ key words like G23 to get this answered.
I remember something about using parts of three different engines to make this.
(F,H,K)
But an interesting combo non the less.
