my clutch gone again???
Old Apr 7, 2005 | 09:50 PM
All Motor Ek99's Avatar
Default my clutch gone again???
ok recently my clutch got replaced cuz it burned out so the clutch is fairly new a week or 2 old and lately i cant chirp 2nd gear, if the car is cold i can and the gear slams in but when the car warms up the clutch slips after the 1-2 shift what is wrong???
Old Apr 7, 2005 | 10:09 PM
QuarterMileMaster's Avatar
Default Re: my clutch gone again??? (dmxarnold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmxarnold &raquo;</TD></TR><TR><TD CLASS="quote">ok recently my clutch got replaced cuz it burned out so the clutch is fairly new a week or 2 old and lately i cant chirp 2nd gear, if the car is cold i can and the gear slams in but when the car warms up the clutch slips after the 1-2 shift what is wrong???</TD></TR></TABLE>
Did you do a proper break in period???? Doesn't sound like it at least, when you put in a new clutch you usually need to go 350-500 miles of easy shifting in order to break it in. Otherwise, you just burnt up another clutch....
Old Apr 7, 2005 | 11:10 PM
LShatchie's Avatar
Default Re: my clutch gone again??? (QuarterMileMaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuarterMileMaster &raquo;</TD></TR><TR><TD CLASS="quote">Did you do a proper break in period???? Doesn't sound like it at least, when you put in a new clutch you usually need to go 350-500 miles of easy shifting in order to break it in. Otherwise, you just burnt up another clutch....</TD></TR></TABLE>
Old Apr 7, 2005 | 11:35 PM
HBK_DAVIDDD's Avatar
bump
Old Apr 7, 2005 | 11:49 PM
drussell4801's Avatar
did you happen to mess with the cable adjustment??
Old Apr 7, 2005 | 11:59 PM
Vrooomski's Avatar
TIGHT
Old Apr 8, 2005 | 06:51 AM
EP3_05's Avatar
Probably improper break in period, crappy clutch, or the flywheel was not resurfaced before installing the new clutch.
g0tgot
Jul 5, 2007 10:28 AM
dynamyks
Aug 21, 2005 02:46 AM
RemerLex11
May 12, 2005 10:04 PM
tzonni
12
Dec 10, 2003 05:49 AM
faultofhumanity
30
Sep 13, 2003 10:47 PM
