b16 cams question sir II vs obdo b16
Old Apr 7, 2005 | 09:47 PM
spun Vtec's Avatar
Default b16 cams question sir II vs obdo b16
Are obdo crx sir b16a cams the same as the 92-95 b16sirII cams.
if not what is the defference
ate the motors the same hp? or is that a tuning issue (obd1 vs obd2)
thanks
spun
Old Apr 7, 2005 | 09:58 PM
FalkenSiR's Avatar
Default Re: b16 cams question sir II vs obdo b16 (spun Vtec)
I know for sure that the sirI cams are different from the B16A2 (99-00 si). Now, I'm not aware of being any difference between teh sir1 and the sir2 cams other than the computer.
Although I once heard someone say the sir2 had 170 hp, I woudnt be too sure about it.
Old Apr 7, 2005 | 10:15 PM
Nerologic's Avatar
yeah the cams are diff, the A2's have a bit longer duration and i think they are a bit bigger, i dont know how much more though...
Old Apr 7, 2005 | 10:37 PM
Redline130's Avatar
The SiRII motor also has a slightly higher c/r. 10.4 vs. 10.2 for the 1st gen. B16A's. From what I understand, B16A cams improved slightly over the years.
Old Apr 8, 2005 | 07:53 AM
spun Vtec's Avatar
Default Re: b16 cams question sir II vs obdo b16 (Redline130)
how much difference woud the sirII cams make in a regular jdm obd0 b16?
Old Apr 8, 2005 | 08:00 AM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">how much difference woud the sirII cams make in a regular jdm obd0 b16?</TD></TR></TABLE>
I would guess about 4 hp. Some peopole use stock gsr cams too as an upgrade over 1st gen B16 bumpsticks.
The extra 10hp made in the 2nd gen B16 comes from a 60mm TB, better intake manifold, cams, and higher compression.
Old Apr 8, 2005 | 09:12 PM
spun Vtec's Avatar
Default Re: b16 cams question sir II vs obdo b16 (Deetz)
this would be going in my everyday driver................ dosnt make that much diff to me i guess i wont invest it would be like 100$ total to have them in my b16 but for about 4hp its not really worth it in my edd.
90B16aCRXsi
28
Dec 5, 2007 07:24 PM
stockb18c
Oct 25, 2006 03:51 PM
riceball777
May 2, 2003 05:07 AM
brownshigh
Aug 5, 2002 07:16 PM
