Valve Cover breather line... what to do with it?
Old Apr 7, 2005 | 08:35 PM
Johnny_Rocket's Avatar
Default Valve Cover breather line... what to do with it?
K, 93 LS-T running about 6 psi daily... I didn't think it was a good idea to connect my valve cover breather line to my intake seeing that it would force air into the valve cover under boost... What are you supposed to do with it? Put a little breather filter on it and call it a day?
Old Apr 7, 2005 | 10:40 PM
elpiar's Avatar
Default Re: Valve Cover breather line... what to do with it? (JohnnyH)
That's an interesting question, never thought of that before.
Any takers?
Old Apr 7, 2005 | 10:43 PM
mtber's Avatar
Run a dump line or a breather filter etc.
Old Apr 7, 2005 | 11:43 PM
s2kdre's Avatar
Default Re: (mtber)
you just put a filter on it or leave it open. you can run up to 15psi on a stock pcv system without a catch can.
Old Apr 8, 2005 | 06:25 AM
Default Re: (jdmhonda)
Alright, sounds easy enough.
Thanks
Old Apr 8, 2005 | 06:43 AM
B18C1CYA's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Run a dump line or a breather filter etc.</TD></TR></TABLE>
Old Apr 8, 2005 | 06:54 AM
EJ1 wilcox's Avatar
Default Re: (B18C1CYA)
Read dasher's thread about crankcase ventilation...
Here ----&gt; https://honda-tech.com/zerothread?id=1199935
Then you can figure out which route you want to go.
The stock PCV system is NOT okay for boost, you need to modify it or you will damage your engine.
Old Apr 8, 2005 | 07:25 AM
Stewie's Avatar
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
The stock PCV system is NOT okay for boost, you need to modify it or you will damage your engine. </TD></TR></TABLE>
how do you figure? Many factory turbocharge cars use a pcv system similar to what honda uses.
Old Apr 8, 2005 | 07:41 AM
EJ1 wilcox's Avatar
Default Re: (Stewie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stewie &raquo;</TD></TR><TR><TD CLASS="quote">how do you figure? Many factory turbocharge cars use a pcv system similar to what honda uses. </TD></TR></TABLE>
Factory turbocharged cars have different PCV setups than factory NA cars like Hondas...
The PCV valve normally opens and vents the crankcase pressure when there is vacuum in the intake manifold... as soon as there is positive pressure in the IM the PCV valve closes and you have no crankcase ventilation anymore.... zero crankcase ventilation under boost is a bad thing...
If there is something I am missing let me know. I have been reading a lot about this lately and trying to learn as much as possible.
Old Apr 8, 2005 | 07:52 AM
YiNYaNg's Avatar
I did the method of using the intake from the turbo to the valve cover..to prevent nasty stuff I put a inline fuel filter...works very good..the casing of the fuel filter is clear and so far I can see all the crap that gets sucked out from the valve cover and gets trap in the fuel filter and prevents it from messing up my compressor...
Old Apr 9, 2005 | 09:40 PM
alex#2's Avatar
Default Re: (H-T)
I'm a retard. I've been wanting to put a catch can b/w my turbo inlet and the valve cover but I never thought of one of those clear fuel filters. THANKS!
I'm wondering if a check valve would be overkill.
Old Apr 10, 2005 | 05:06 PM
thelate1's Avatar
Default Re: (H-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T &raquo;</TD></TR><TR><TD CLASS="quote">I did the method of using the intake from the turbo to the valve cover..to prevent nasty stuff I put a inline fuel filter...works very good..the casing of the fuel filter is clear and so far I can see all the crap that gets sucked out from the valve cover and gets trap in the fuel filter and prevents it from messing up my compressor... </TD></TR></TABLE>
could you post a diagram of this setup your running?
thanx
Old Apr 11, 2005 | 05:26 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">If there is something I am missing let me know. I have been reading a lot about this lately and trying to learn as much as possible. </TD></TR></TABLE>
You pretty much hit the nail right on the head. Reading dasher's thread is the best place to start.
fryman
Apr 3, 2013 04:12 AM
turbo boost
Mar 11, 2007 09:11 AM
AntiStock
Dec 26, 2005 04:10 PM
Bambooseven
Sep 22, 2004 10:51 AM
Prelude91siT
Jan 1, 2004 10:42 AM
