88 CRX with B18A LS Non-VTEC? Running?
Old Apr 7, 2005 | 07:59 PM
michaelharper11's Avatar
Default 88 CRX with B18A LS Non-VTEC? How fast is it?
I have recently purchased a manual 88 CRX with a non VTEC B18A LS motor. It is equipped with coilovers, stage 2 clutch, 4-2-1 headers and exhaust and an intake. I haven't went and picked the car up yet, but what kind of numbers can I expect to be running in the 1/4 and horsepower.
Old Apr 7, 2005 | 09:15 PM
31flavorscivic's Avatar
Default Re: 88 CRX with B18A LS Non-VTEC? How fast is it? (michaelharper11)
i had a friend with similar setup run low 15s, high 14s with good driving.
HP @ crank: something like 150 with bolt-ons.
Old Apr 7, 2005 | 10:19 PM
FalkenSiR's Avatar
Default Re: 88 CRX with B18A LS Non-VTEC? How fast is it? (31flavorscivic)
too many variables like most would say. I'd say low 15's.
Old Apr 8, 2005 | 04:50 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">HP @ crank: something like 150 with bolt-ons.</TD></TR></TABLE>
Unless the motor is a 1992+ motor running the proper ECU, 150HP at the crank is doubtful. MUCH more common is to use a 1990-1991 motor. And that motor only produces 130HP stock at the crank. i/h/e is not going to bring the power up by 20HP.
Old Apr 8, 2005 | 05:39 AM
Default Re: 88 CRX with B18A LS Non-VTEC? How fast is it? (StorminMatt)
I am not real sure what year the motor is out of, but the guy told me that it had around 175 HP, but it sounds like that is bullshit. I am going to bolt on a Garrett T3/T4 Turbo Setup with lightweight pulleys, cam gears, and new manifold with an intercooler and hope that will put me in the 13's. What do ya'll think?
Old Apr 8, 2005 | 05:42 AM
CRX_LSVTEC's Avatar
i had the same setup you had
1989 crx si, w b18a 1990 integra with integra tranny. bolt ons.
15.4 is what you will run on street tires...maybe 15.2
have fun....
engine is 130hp you have about 148 on a good day.....
but you also added 130 lbs easy to car....which is another passenger
Old Apr 8, 2005 | 06:07 AM
green91's Avatar
its 130 crank hp... with bolt ons you could reasonably expect 110-120 whp
Old Apr 8, 2005 | 06:36 AM
Default Re: (green91)
ANY IDEAS ABOUT WHAT I CAN EXPECT WITH MY TURBO SETUP?
Old Apr 8, 2005 | 06:40 AM
RACINTWEEK's Avatar
there was on article in SCC about a 91 Si w/ a 92 LS i/h/e no cat that put ~140 to the wheels. it was re-built (stock) so i'm sure that helped
but that is wishful thinking, here is what you should expect
nelsonb16
Jan 21, 2008 04:29 PM
b19coupe
Sep 25, 2007 07:48 PM
kid-crx
Apr 27, 2005 05:49 PM
prcrx124
Apr 25, 2004 12:35 PM
LSBeast
Aug 30, 2002 06:58 PM
