!!!Help wiring a GM horn to my prelude, keeps blowing fuses!!!
Old Apr 7, 2005 | 07:19 PM
eluder33's Avatar
Default !!!Help wiring a GM horn to my prelude, keeps blowing fuses!!!
I searched with no answer. I got a GM horn from a junk yard and am trying to wire it up correctly but I can't get it right for some reason. I got the honda wires (blue and white) and the GM wires (green and black) and a ground spliced in (pos or neg? ) but I have tried every combination and none seem to work but one that I sloped together but when I spliced them it didn't work. SO what colors go to what and where do I connect the ground to (pos or neg) sorry I'm bad at electronics
Old Apr 7, 2005 | 08:31 PM
Cashis Lee's Avatar
Default Re: !!!Help wiring a GM horn to my prelude, keeps blowing fuses!!! (matty c)
I was actually thinking of doing the same thing, but I picked up some FIAMM horns instead.
Maybe the GM horns draw more current than the OEM Prelude horns? In that case you may have to run relays.
Old Apr 8, 2005 | 06:28 AM
eluder33's Avatar
Default Re: !!!Help wiring a GM horn to my prelude, keeps blowing fuses!!! (Cashis Lee)
anyone else that can help me, I don't like driving w/o a horn
Old Apr 8, 2005 | 06:36 AM
tspencer227's Avatar
Hmmmm....I'd say try installing a higher- rated fuse in the box, and see if you can find schematics of a typical GM car the horn would be installed in- it is possible that the new horn is designed to draw more current than the Honda one.
Old Apr 8, 2005 | 06:53 AM
eluder33's Avatar
I tried higher rating fuses but they still blow. I had it mocked up to where it would work fine but when it was all spliced it wouldn't, so I know there is a right way to do it.
Old Apr 8, 2005 | 08:31 AM
Default Re: (matty c)
Hmm. Are you sure you didn't cross- wire positive and negative? I'd say to try and trace the wires all the way back. Or again, try and get a hold of a GM schematic. Where is your ground connection spliced into the system?
TracerAcer2.2L
21
Oct 23, 2015 09:46 PM
micah_m
Audio / Security / Video
May 17, 2013 08:58 AM
LSRracing95
Apr 23, 2005 09:36 AM
Neuspeedx
Welding / Fabrication
Apr 5, 2005 05:55 PM
Alex6686
Feb 6, 2005 10:02 AM
