Bad LMA's?
Old Apr 7, 2005 | 04:26 PM
96b18c's Avatar
Default Bad LMA's?
I recently pulled my head and had it cleaned but one thing I didn't do was soak the LMA's in oil before putting them in. I heard that this could lead to a loud ticking if you don't do it. I did the valve adjustment twice and am wondering that if it is the LMA's and they are ticking, are they also not going to be working properly?
Old Apr 8, 2005 | 07:36 PM
96b18c's Avatar
Default Re: Bad LMA's? (96b18c)
ttt
Old Apr 9, 2005 | 04:07 AM
LSVTEC 91 Civic's Avatar
Banned
If they're ticking they aren't working properly... Same thing happened with my LMAs, then I replaced them with H22 spring type LMAs, no more worries.
Old Apr 9, 2005 | 10:58 AM
_BEN_'s Avatar
Default Re: Bad LMA's? (LSVTEC 91 Civic)
Could you tell if one was not working correctly if you pushed down on the vtec follower?
I have encountered one that stuck, but never a failed or malfunctoning lma.
Old Apr 9, 2005 | 07:51 PM
Banned
Default Re: Bad LMA's? (_BEN_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">Could you tell if one was not working correctly if you pushed down on the vtec follower?
I have encountered one that stuck, but never a failed or malfunctoning lma. </TD></TR></TABLE>
I'm not 100% sure about the VTEC follower.
When my LMAs were bad, I heard the ticking (sounded like marbles rolling around in the head) until VTEC engaged, then the noise went away.. thats how I knew it was my LMAs. Mine were stuck.
Old Apr 10, 2005 | 12:10 PM
96b18c's Avatar
so I should probably shoudn't be pushing my car much till I replace them huh? Is it ok to drive it though?
Old Apr 10, 2005 | 04:20 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96b18c &raquo;</TD></TR><TR><TD CLASS="quote">s Is it ok to drive it though?</TD></TR></TABLE>
Yep, I did for a 7k miles...
Old Apr 11, 2005 | 11:18 AM
96b18c's Avatar
7k miles then you broke something or replaced them? Thanks
Old Apr 11, 2005 | 07:09 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96b18c &raquo;</TD></TR><TR><TD CLASS="quote">7k miles then you broke something or replaced them? Thanks</TD></TR></TABLE>
Broke a valve spring, so it was a perfect opportunity to replace 'em. Didn't break anything, honestly I don't even think its that big of a deal... they're just loud and annoying.
I would replace with the Lude LMAs as soon as you get around to it though.
h22ek9forme
Nov 22, 2007 08:16 AM
bskhonda
Oct 9, 2007 06:19 AM
9000rpms
May 15, 2006 02:26 PM
bard329
Nov 22, 2005 11:15 AM
n00bs suck
19
Oct 14, 2004 07:46 PM
