Redline
Old Jan 28, 2002 | 03:01 PM
prelude10's Avatar
Default Redline
Is it bad if i take my car to 8000 grand and then shift. I know the max power is at 7000rpms and redlines a 7400. I have a 5sd 5th gen.
Old Jan 28, 2002 | 03:04 PM
laughinxxx's Avatar
New User
Default Re: Redline (prelude10)
It will increase the rate of engine wear and you are getting closde to the fuel cut as well. Just don't take it above 8000 rpm and don't redline everyday.
illusion's Avatar
depends on your definition of "bad".
Old Jan 28, 2002 | 03:08 PM
Quaalude's Avatar
i would just take it to 7500 rpm...peak power tops off at around 7000 actually rpm (from my dyno plots)...the factory tach is off about 200 rpm...if u go past 8000, the rev limiter kicks in
Old Jan 28, 2002 | 03:37 PM
illusion's Avatar
Default Re: Redline (Quaalude)
the reason to take it to 8000 is because, yes, your power is declining, but its probably close to equal to the power of the rpm of the next gear you are going into if you shift at 7500. so the power will be around the same, but when you take it to 8000, your next gear will be higher in the powerband range (will be in vtec) which will be more hp.
Old Jan 28, 2002 | 05:51 PM
976's Avatar
976
New User
Default Re: Redline (illusion)
Either bend a valve
Snap a belt
Wear electical parts
Oil heats soo much is doesn't protect - cylinder walls grind metal to metal
Not very smart bro... Be careful!!!
[Modified by B21A, 2:54 AM 1/29/2002]
Old Jan 28, 2002 | 06:30 PM
Toretto's Avatar
Default Re: Redline (B21A)
I have done it when I want to go very fastI have heard the fuel cut off is actaully at about 7700rpm, and on my tach, its not till 8200, so the engine is reving as high as you might think. I wouldnt do it all the time, just when racing.
Old Jan 28, 2002 | 07:06 PM
DirtyLude's Avatar
Default Re: Redline (Toretto)
If your not hitting the fuel cut when autocrossing, you're not racing. Go home.
7600 is fuel cut, which is indicated anywhere from 8000 to 8100 on peoples tachs. Don't worry about it. If your tracking it all the time and hitting the fuel cut and running it on the edge, I would start to worry about it, but a few times doesn't hurt anything. It sure doesn't sound pretty, though.
Old Jan 28, 2002 | 08:02 PM
Import RP's Avatar
Default Re: Redline (DirtyLude)
I always shift at redline...but maybe thats just me. I'd rather have my car longer then lower my time .1 seconds or something.
B_Swapped93
17
Apr 4, 2013 12:51 PM
pmachan
Jan 19, 2006 11:45 AM
projectegr
12
Jan 15, 2005 05:05 AM
Broken Devil
Jul 31, 2004 02:05 PM
RAB
Sep 12, 2002 09:37 AM
