Engine mounts for D16Z6 to JDM B16A2 swap
I can't seem to find a clear answer to this question in the archives so I would like to hear from someone that actually did this swap.
I'm planning on installing a 92-95 JDM B16A2 in my 1992 Civic Si (D16Z6) and I need to know what engine mounts are needed if any.
That's the thing, the mounts are a 100$ extra option and I would rather put that 100$ somewhere else if I don't need them.
I found an old post where someone said you only needed the bracket bolted to the engine in the timing cover. Can anyone confirm this?
Here's what you need:
right front tranny mount from integra, kept the civic front driver side rubber
mount. timing belt side mount bracket is needed which should be on the engine,
reuse the civic timing belt side rubber mount (93-95 ex/si), resuse the civic top
tranny mount, get integra rear engine bracket but can reuse the civic rubber
mount.
mount.
v-tecnition
14
Jun 12, 2010 02:53 PM
B19CivicHB
Jul 3, 2002 12:31 PM
