What is the best way to take the plastic cover off the gas pedal?
Old Jan 28, 2002 | 02:28 PM
CWITR's Avatar
Default What is the best way to take the plastic cover off the gas pedal?
Dont want to mess anything up if I dont have to.
Old Jan 28, 2002 | 02:30 PM
Phoenix_ITR's Avatar
Default Re: What is the best way to take the plastic cover off the gas pedal? (CWITR)
i believe that you have to use a screwdriver or pliers to pry the clips off the top of the pedal and then slide the cover down and off.
Old Jan 28, 2002 | 02:34 PM
Jim80y's Avatar
Use pliers, start from the top left corner and pull down, you will probably end up ruining the cover cos its pretty hard to get off.
CWITR's Avatar
Default Re: What is the best way to take the plastic cover off the gas pedal? (delinquent)
Thanks, I got it off w/o breaking anything.
Actually I didnt ruin it and can use it again if I want.
[Modified by CWITR, 3:35 PM 1/28/2002]
Old Jan 28, 2002 | 02:37 PM
heh...impressive, i must say...
Old Jan 28, 2002 | 03:16 PM
Stock R's Avatar
hmmm?
no need for pliers. just pull from the bottom.....
i did that for all my rubber pedals.
Old Jan 28, 2002 | 03:21 PM
Default Re: What is the best way to take the plastic cover off the gas pedal? (Stock R)
hmmm?
i think he was referring to the hard plastic cover on the gas pedal.
Old Jan 28, 2002 | 04:23 PM
H-PIMP's Avatar
Ditto, quite impressive. I mangled mine getting it off. When I installed my mugen pedals.
Old Jan 28, 2002 | 04:47 PM
magic hat #9's Avatar
Default Re: What is the best way to take the plastic cover off the gas pedal? (H-PIMP)
my pedal cover was destroyed. in fact, i bent the damn metal pedal itself. i got that cover off though.
Old Jan 28, 2002 | 04:50 PM
jet's Avatar
jet
New User
Default Re: What is the best way to take the plastic cover off the gas pedal? (monkey_truckR)
i fiddled with my pedal to remove this damn cover for 15 minutes, cursing and spitting i ask my brother to look at it and in 30 seconds...OFF no damage to cover or pedal
Old Feb 4, 2002 | 10:11 AM
CWITR's Avatar
All you need to do is slip a screw driver up the back and lift up. Then it slides right off. I used the instuctions from the Honda Access Pedals I bought but never used.
Old Feb 4, 2002 | 10:15 AM
sgT's Avatar
sgT
I leave it on because it raises the gas pedal up and makes it easier to heel-toe
Old Feb 4, 2002 | 10:20 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: What is the best way to take the plastic cover off the gas pedal? (sgT)
when the hell do you ever do that Steve
Old Feb 4, 2002 | 10:23 AM
Chris's Avatar
Default Re: What is the best way to take the plastic cover off the gas pedal? (Ross)
LOL! I thought the same thing... sgT..the ROADRACER?????
Old Feb 4, 2002 | 10:27 AM
sgT's Avatar
sgT
Default Re: What is the best way to take the plastic cover off the gas pedal? (Chris)
you know what they say when you ASSume.........
Old Feb 4, 2002 | 10:29 AM
Ross's Avatar
25 Year Member
Community Builder
do you heel/toe with the 13" Daytons on there? lol
Old Feb 4, 2002 | 10:35 AM
sgT's Avatar
sgT
daytons??
you know i heel-toe with that three wheel motion!
Old Feb 4, 2002 | 07:11 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
damn! you guys are brutal....
Pat
Aug 4, 2023 07:08 AM
jbell
Honda S2000
16
Sep 18, 2008 06:26 PM
Jesterian
Dec 19, 2005 01:02 PM
Sound Streamin'
Nov 4, 2004 07:14 PM
dLo GSR-stolen-now-WRX
Nov 6, 2002 12:41 PM
