EF D15B2 strange... stopped running, weird things found, PLEASE HELP!
Old Apr 7, 2005 | 10:02 AM
phil300z's Avatar
Default EF D15B2 strange... stopped running, weird things found, PLEASE HELP!
Alright, the engine WAS running rich & engine light was on, but I didn't check the codes - drove it for a couple days (and just puchased it). Yesterday I mess around w/the timing, but then set it back near the center. Find a couple vacuum leaks, and one that is totally crimped off, but don't have any pipe. So yesterday I back up to go to the parts store, then go to pull forward (engine is idling fine at this point), lightly press the gas & it revs maybe 100-200rpm faster, then a "click" noise from the engine & it starts to bog down like its going to stall... I quickly take foot off gas & fully depress the clutch.
"What was that!"
I try to go rev again & it does the same thing, so I turn around on idling power & park, turn the car off. Now I try to start & nothing happens (just turns over & over, no ignition whatsoever). For some reason I get the idea to pull the plug wires out & the 2 plugs on the left have a lot of oil in them, the 2 on the right are dry. I thought the cam may have broken so I took off the valve cover & it turns everything in there is just fine. I run the ECU codes today & get
#5 Map Sensor
#10 Intake Air Temperature Sensor
#16 Fuel Injector System
First, any clue what is going on with my car? I don't have my hayes manual with me, so please point me to where these sensors are located. Also, why would I have oil in my first 2 spark plug "tubes??"
PLEASE HELP!
Thanks guys
Old Apr 7, 2005 | 10:56 AM
91si pumpkin2's Avatar
when You say oil in your park plugs are you saying around the spark plug or on the side that sparks because if it is around the side that has thread it is probably your seals on your valve cover.But if it is on the side that sparks you are most likely looking damaged rings on tour 2 spark plugs
Old Apr 7, 2005 | 11:46 AM
Mr_Si-R's Avatar
how do you check ecu codes?
JDMEF
Jan 24, 2012 11:26 AM
redsidriver
Feb 26, 2009 08:46 PM
2gen_tegs_rule
12
Oct 14, 2006 06:14 PM
B18B EK
Jun 19, 2005 05:41 PM
ZoNe_HKS
Sep 17, 2002 04:19 PM
