Question about Scholth(sp?) harness with or without Roll Bar.
Old Jan 28, 2002 | 01:53 PM
RATEDR's Avatar
Default Question about Scholth(sp?) harness with or without Roll Bar.
Ok I plan to get a Autopower roll bar and then a 4 or 5 point harness of some kind.
But I have a track event coming before I will be able to get the roll bar. I have no harness to use for the event and would like one cause the stock seat belt just isnt cutting it.
So here are my questions: I know the Schloth (SP?) harness works with factory mounting points. Could I use this harness when I get the Autopower rollbar or will I have to buy another to go with that?
Anyone know a good place to buy the harness?
TIA
Old Jan 28, 2002 | 01:54 PM
Back in Black's Avatar
Rather OG
Default Re: Question about Scholth(sp?) harness with or without Roll Bar. (RATEDR)
Sorry for this TJ, but...
DON'T WEAR A HARNESS WITHOUT BAR/CAGE PROTECTION!!!
Old Jan 28, 2002 | 01:55 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: Question about Scholth(sp?) harness with or without Roll Bar. (darth vadeR)
x 10
I've run many track events with the stock seatbelts. They aren't that bad.
Old Jan 28, 2002 | 01:56 PM
Cosworth's Avatar
TJ - try this trick to secure youself w/ a stock seatbelt... twist it around 3-4 times and then buckle... it should hold you tighter, try it.
Old Jan 28, 2002 | 01:57 PM
ZygSpeed's Avatar
The Schroth harness are street legal, whereas most of the race versions are not (believe it or not).
If you're going to eventually get a roll bar or cage, I'd wait til then to bet some "real" belts.
The "harness guide bar" you IM'd me about is from http://www.speedwaremotorsports.com in Washington state (about $400 or so).
Old Jan 28, 2002 | 02:04 PM
ZygSpeed's Avatar
Sort of like ... safe sex (protection).
Oh well ...
Old Jan 28, 2002 | 02:05 PM
Rather OG
Default Re: Question about Scholth(sp?) harness with or without Roll Bar. (zygspeed)
Oh well ...
Only you Ed, only you...
Old Jan 28, 2002 | 02:07 PM
RATEDR's Avatar
ok cool..thanks everyone...Ill run my event with the stock seat belts.
Rather OG
Old Jan 28, 2002 | 02:09 PM
Yellow Dragon's Avatar
I have the SCHROTH Ralleye 3 harness. It fits to the two stock side mounting locations and it forms a "Y" in the rear mount and I have mine mounted to the top point of my rear seat belt location. Works great and *was* GS legal for AutoX.
I have used it for two roadcourse events as well and it works fine. If I were racing competitively...then I would consider a rollbar/cage. I'm not...so I won't ever go competitive with my ITR and I think it works fine.
Old Jan 28, 2002 | 02:12 PM
ZygSpeed's Avatar
Which is why I've not yet installed my sparco belts! either
But I'm thinking about it!
Old Jan 28, 2002 | 04:23 PM
If you want a harness bar, get one from http://www.ioportracing.com
http://www.ioportracing.com/restrain...chor4293618095
Only $100!
Rudaluda
Welding / Fabrication
Apr 13, 2009 10:08 PM
chunkybs
64
Jan 17, 2007 10:28 AM
thehatchninja
10
Mar 22, 2005 08:30 PM
Powered by Honda
15
Mar 5, 2004 06:54 AM
2fstGSR
65
Mar 11, 2003 06:32 AM
