Issues with DRAG mani and Air Research T3/T4 opinions wanted on solution...
Old Apr 7, 2005 | 06:28 AM
Boosted96EK's Avatar
Default Issues with DRAG mani and Air Research T3/T4 opinions wanted on solution...
The issue is the following... threaded holes on the DRAG mani to mount the turbo are bigger than the ones on the turbo's flange... I know I can drill the holes on the turbo's flange to make them bigger and be able to bolt the turbo to the mani... Now, the holes on the turbo's flange are threaded... when I make the holes bigger on the flange, should I thread the new bigger holes on the turbo's flange?
One more question... should I use bolts with lock washers or studs with a locking nut and washer to mount the turbo to the mani?
Old Apr 7, 2005 | 09:20 AM
Default Re: Issues with DRAG mani and Air Research T3/T4 opinions wanted on solution... (Boosted96EK)
bump... help a boost virgin out
Old Apr 7, 2005 | 12:08 PM
dustin's Avatar
What the heck turbo are you trying to use? Hehe.
Drill turbo out... don't need to tap the holes.
You can use bolts or studs. Whatever eases installation. Studs are usually easier to use but harder to find
Old Apr 7, 2005 | 01:55 PM
Default Re: Issues with DRAG mani and Air Research T3/T4 opinions wanted on solution... (dustin)
thanx dustin... just wanted to make sure...
WestTxSR20
Aug 18, 2009 12:19 PM
aaroboost
Sep 16, 2006 06:41 AM
jason190
Welding / Fabrication
Apr 1, 2005 12:29 PM
GOLDBERG
Dec 26, 2002 06:40 PM
LSturboHB
Feb 1, 2002 08:26 PM
