B16A Race Block Specials starting at $1395.00 CORE Included. Sleeved, Pistons, Exospeed Race Engine
Exospeed B16A Fully Built Race Block Special starting at $1395.00
Comes with Core!
Race Blocks starting at $1395.00
* Picture shown: Stage 4 Turbo Block
<U>Stage 2a All Motor high compression street setup. $1395.00</U>
Pistons: CTR, ITR or B16A pistons
OEM B16A rods
Honda OEM Bearings: rod and mains
Honda OEM Bottom end gasket kit; Oil pan gasket, oil pickup gasket, main seals.
Honda OEM Oil pump
Bore and Hone with clearances for pistons
Micropolish crank
Hot tank
Step Deck
Labor: Measure bearings
Labor: Assembly
<U>Stage 2b: All Motor or Turbo(12-15psi) $1695.00</U>
Arias Pistons 81.5mm, Compression - 9.1:1 or 11.3:1
OEM B16A rods
Honda OEM Oil pump
Bore and Hone with clearances for Arias pistons
Micropolish crank
Hot tank
Step Deck
Labor: Assembly
<U>Stage 3: All Motor or Turbo(15-18psi) $1995.00</U>
Arias Pistons 81.5mm, Compression 9.1:1 or 11.3:1
Eagle Rods with ARP bolts
Honda OEM Oil pump
Micropolish crank
Hot tank
Step Deck
Labor: Assembly
<U>Stage 4: All Motor or Turbo(19psi+) $2695.00</U>
Arias Pistons 81.5mm to 86mm, Compression from 8:1 to 12:1 [Custom compression pistons avail.]
Exospeed Open Deck Sleeves
Honda OEM Oil pump
Micropolish crank
Hot tank
Step Deck
Labor: Assembly
** Block Cores include: Block, crankshaft, main seal cover and main caps
Add for New Honda Parts
OEM Honda Oil Pick up w/bolts: $42.00
OEM Honda Baffle Plate w/bolts: $39.00
OEM Honda B16A Oil Pan w/bolts: $95.00
AEBS B16A Head studs $115.00
OEM Honda Head Gaskets: PM for price
Comes with Core!
OEM B16A rods
Honda OEM Oil pump
Micropolish crank
Hot tank
Step Deck
Labor: Assembly
OEM B16A rods
Honda OEM Oil pump
Micropolish crank
Hot tank
Step Deck
Labor: Assembly
Honda OEM Oil pump
Micropolish crank
Hot tank
Step Deck
Labor: Assembly
Honda OEM Oil pump
Micropolish crank
Hot tank
Step Deck
Labor: Assembly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues »</TD></TR><TR><TD CLASS="quote">What is the turnaround ?</TD></TR></TABLE>
depends on the build. PM me which one you are interested in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">How much if we provide a core?</TD></TR></TABLE> PMEd.
Is this just a one time special? or is it gonna be available for a long time? I was gonna go to you guys to get my B18C built once I bought a core to send in. But I like this B16 special where I dont have to provide a core. The one I'm looking at is the sleeved stage 3 or maybe even stage 4, cause I'm gonna be boosting. Also are you guys able to provide blocks from specific years?
EDIT: just wanted to make sure too, are the stg 3 blocks sleeved or not?
Thanks
Thanks
Its a limited time until we run out of B16A cores.
We only have B16A1 cores. Theyre all thoroughly inspected and guaranteed that its a good block to build.
thanks for the info, I think I'm just gonna use the same bloc I have in there now. I'll look you guys up in a month or two, or whenever I decide to get my B18C sleeved and built then.
thanks
thanks
ExospeedAMcrx
Jul 20, 2005 11:55 AM
