/valve Adjustment question
Old Apr 6, 2005 | 08:31 PM
LudeChild's Avatar
Default /valve Adjustment question
Just out of curiousity, in the helms manual it says
note: After adjusting, retorque the crankshaft pulley bolt to 177 N-m (18.0 kgf-m, 130 lbt-ft).
what does this mean?
Old Apr 6, 2005 | 08:40 PM
jdmaek's Avatar
Default Re: /valve Adjustment question (LudeChild)
u make sure the bolt is tight to that spec, it may have gotten loose
Old Apr 6, 2005 | 08:55 PM
homesauce's Avatar
Default Re: /valve Adjustment question (jdmaek)
They tell you to rotate the crankshaft using that bolt, so it may have come loose, but i doubt it since that thing is torqued to crazy specs.
Old Apr 7, 2005 | 12:39 AM
prelude1897's Avatar
Default Re: /valve Adjustment question (homesauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce &raquo;</TD></TR><TR><TD CLASS="quote">They tell you to rotate the crankshaft using that bolt, so it may have come loose, but i doubt it since that thing is torqued to crazy specs.</TD></TR></TABLE>
Hell yeah it is...Me and a couple of other friends tried changing a timing belt about 2 weeks ago, and we couldn't get that bolt off at all. Its on there soooo damn tight that we broke an extension and a breaker bar, after that, we just quit and put everything back together.
Old Apr 7, 2005 | 02:36 AM
chandler's Avatar
thats why they invented the ingersol 231, one of the best impact guns I have ever bought
itr1244
Aug 5, 2007 11:19 PM
imadigitalgod
10
Jun 28, 2006 10:24 AM
citrus3000psi
Jan 4, 2006 10:32 PM
whitenameseboi
Mar 25, 2005 02:47 PM
14bcoupe
Nov 22, 2004 06:57 AM
