wheel shimmy
Old Apr 6, 2005 | 08:29 PM
NorthernXposure's Avatar
Default wheel shimmy
whats up fellaz... under heavy acceleration i get a pretty bad wheel shimmy from 55mph and up... i rotated and balanced all the tires and still no luck... you guys have any ideas... im really hoping its not my rotors.... i just put a set of stoptechs all the way around about 5k ago. thnx in advance fellas
Old Apr 6, 2005 | 08:33 PM
BlueR's Avatar
Default Re: wheel shimmy (NorthernXposure)
unfortunately, thats the first sympton of warped rotors
or have you switch to a different set of brake pads recently?
Old Apr 6, 2005 | 08:39 PM
B2FiNiTY's Avatar
Default Re: wheel shimmy (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">unfortunately, thats the first sympton of warped rotors
or have you switch to a different set of brake pads recently?</TD></TR></TABLE>
He is talking about acceleration and from what I have seen, I have never seen that happen on acceleration, only braking.
Old Apr 6, 2005 | 08:48 PM
BlueR's Avatar
Default Re: wheel shimmy (B2FiNiTY)
oooops
but then why mention the stoptechs rotors?
Old Apr 6, 2005 | 09:10 PM
Mythias's Avatar
Where is the wheel shimmy from? Did it change when you rotated the wheels?
Old Apr 6, 2005 | 09:16 PM
migs's Avatar
BlueR needs reading comprehension skills.
Spin the wheels on the balancer machine and check for out of roundness. Also what type of wheels are on your car?
Old Apr 6, 2005 | 09:20 PM
BlueR's Avatar
Default Re: wheel shimmy (migs)
bah, to all j00 fools: if there is a problem with the wheels or tires, it should have the shimmy at all speeds both under braking and acceleration
i am still wondering why he mentioned the rotors?
Old Apr 6, 2005 | 09:56 PM
i mentioned rotors for the simple fact that they do get warped and cause wheel vibration.. although when my brakes are being applied i have no wheel shimmy....
any other ideas fellas&gt;&gt;&gt; bent CV, bad motor mount, i havnt check these yet simply because it has been cold up here in the big AK..
im currently running stock wheels and suspension... and my tires have all even wear all the way around... when the tires were rotated it didnt feel like the vibration moved
Old Apr 7, 2005 | 04:15 AM
SpoolnEG6's Avatar
If your wheels are in balance and wheels are in line then their is a possibility of a broken belt in the tire or that they are just chopped from hard driving. I used to work for a tire shop and these were the two main causes besides balance and wheels being out of round.
Old Apr 7, 2005 | 06:50 AM
ericlee303's Avatar
If you are running aftermarket wheels, try buying those hubcentric rings.
I also suspect that warped rotors and cause a shimmy at higher speeds (See Northern Exposure above). My rotors are warped, and my wheels shimmy at about 135kph even though I think my stock wheels are fine.
Old Apr 7, 2005 | 06:57 AM
MattD@Stoptech's Avatar
Default Re: wheel shimmy (SpoolnEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnEG6 &raquo;</TD></TR><TR><TD CLASS="quote">If your wheels are in balance and wheels are in line then their is a possibility of a broken belt in the tire or that they are just chopped from hard driving. I used to work for a tire shop and these were the two main causes besides balance and wheels being out of round.</TD></TR></TABLE>
I doubt it's tire/wheel related since he said that he swap the wheels around. So the vibration would have followed the bad tire/wheel, and aparently it hasn't. i'd suspect either a driveshaft problem, a wheel bearing, or a steering system issue.
Jack the car up and test for play in the up/down and front/back direction by pulling/pushing on the wheel.
Old Apr 7, 2005 | 07:02 AM
ZygSpeed's Avatar
Default Re: wheel shimmy (El Pollo Diablo)
Check the lugnuts, again.
Old Apr 7, 2005 | 07:06 AM
Default Re: wheel shimmy (zygspeed)
I found that the symptoms of loose lugnuts on front wheel tend to be most prominent under coasting down conditions, and almost undetectable under acceleration...but it sure could be the cause of a shimmy.
Old Apr 7, 2005 | 07:08 AM
Chris F's Avatar
I'll be the first to guess LSD.
-Chris
Old Apr 7, 2005 | 07:10 AM
BLacK FirE's Avatar
Could be an axle or a wheel bearing.
Old Apr 7, 2005 | 07:43 AM
Mugen Mike's Avatar
I would check the axles, wheel bearings and tie rod ends.
Old Apr 7, 2005 | 07:52 AM
dnatrance's Avatar
Default Re: wheel shimmy (Mugen Mike)
Also, check your bushings! My friend had the same problem with his civic and it was the big bushing on the front LCA. It was rotten and had a lot of slack. Definatly worth a check
Old Apr 7, 2005 | 09:43 PM
Default Re: wheel shimmy (dnatrance)
thanks for the info fellas... car goes on lift tomorrow
Old Apr 8, 2005 | 05:07 AM
rG`'s Avatar
rG`
Good luck with it!!
And if you get a chance, hit us back with your findings. I'm thinking I might have the same problem. But my tires are in need of replacement so I'm putting it down to the Slip Diff.
Old Apr 8, 2005 | 05:26 AM
Dr Pooface's Avatar
Default Re: wheel shimmy (r`Geno)
wheel bearing
WalkerGSR1
Suspension & Brakes
Aug 13, 2006 02:36 PM
movingIIshadow
11
Dec 7, 2005 05:36 PM
speedehatch
Dec 3, 2003 11:57 AM
bren1339
16
Oct 15, 2003 01:08 PM
tornactive.com
May 3, 2002 06:17 PM
