I want 12's, your input please.
Old Apr 6, 2005 | 05:45 PM
sykotic's Avatar
Default I want 12's, your input please.
I have a 95' LS, stock motor, tranny, clutch/flywheel, and axles.
My turbo setup:
Precision SC61
Drag Manifold
Custom 2.5" downpipe w/ 2.5" exhaust & gutted cat
Tial 38mm wastegate @ 10.15psi
Custom IC piping w/ Greddy Type-S BOV
JRC 5" IC
RC440 Injectors
Uberdata street tuned(timing untouched)
I am planning to get dyno tuning down this upcomming Saturday so it will be tuned properly. Ok, so far from a week ago my best time slip I could pull with this setup was a 14.8 @ 98mph, with a 60' time of 2.5(yuck). How possible will it be for me to pull atleast a 12.9 with my setup. I just want to be able to hit 12's and if I can get a mid-12 all the better. Current options I have considered after the tune are Drag Radials or Slicks, traction bars, and clutch/flywheel. Right now with no further input what i'm thinking is to get the drag radials, and a week or 2 after order the new clutch/flywheel and hold off for the traction bars for a bit.
Do you think these additions to my setup can get me in the 12's? If not, what else should I consider?
Old Apr 6, 2005 | 06:17 PM
nsxmatt's Avatar
You have a setup that should be making almost 300whp, slicks would help you out more than anything. 12's should be easy on slicks.
Old Apr 6, 2005 | 06:41 PM
sykotic's Avatar
Default Re: (nsxmatt)
i really have no clue when it comes to tires, would I be able to mount slicks or drag radials on my stock steelies? what does a set of slicks/drag radials cost? Heh if you have any info on slicks/drag radials or a thread that is a good read to learn something about putting them on our cars, please post it, ive read all threads about drag radials and slicks on here and TI.
Old Apr 6, 2005 | 07:29 PM
1 2 NV's Avatar
Default Re: I want 12's, your input please. (sykotic)
u need it tuned badly, u dont have anywhere near the MPH for 12s. minimum MPH ive seen for 12s is 102 and it sounds close but 14.8@98. you should be running upper to mid 13s with that MPH.
Old Apr 6, 2005 | 09:50 PM
b19coupe's Avatar
Default Re: (sykotic)
Hit up John (SlicksMH)-he can hook you up with a good set of slicks.
https://honda-tech.com/zero...41045
You will also need wheels-I am partial to Bogarts, but Welds and Lensos will also do the trick. You should be able to shave at least 0.6 off of your 60's-which will equal more than 0.6 off of your ET's.
Old Apr 6, 2005 | 10:27 PM
JL's Avatar
JL
so you must have been spinning all the way down the track?
Old Apr 7, 2005 | 02:44 PM
sykotic's Avatar
Default Re: I want 12's, your input please. (1 2 NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">u need it tuned badly, u dont have anywhere near the MPH for 12s. minimum MPH ive seen for 12s is 102 and it sounds close but 14.8@98. you should be running upper to mid 13s with that MPH.</TD></TR></TABLE>
Yea, actually I have the dyno tuning session scheduled for 11am this Saturday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Hit up John (SlicksMH)-he can hook you up with a good set of slicks.
You will also need wheels-I am partial to Bogarts, but Welds and Lensos will also do the trick. You should be able to shave at least 0.6 off of your 60's-which will equal more than 0.6 off of your ET's.</TD></TR></TABLE>
I think i'm leaning more towards drag radials.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JL &raquo;</TD></TR><TR><TD CLASS="quote">so you must have been spinning all the way down the track?</TD></TR></TABLE>
Actually I didn't notice a whole lot of spinning except 1st and 2nd(first 60feet, ha).
Old Apr 7, 2005 | 06:00 PM
Junglesnake's Avatar
I put down 240hp 207 tq on my stock LS and ran a 12.9 at 111mph with a 2.1 60'. This was on 14" steelies w/ azenies in an EK hatch.
hectic57
Feb 9, 2008 07:45 AM
r0iand
Dec 3, 2007 09:07 AM
ALLphilthyDC2
13
May 1, 2007 11:25 AM
sykotic
Apr 16, 2005 11:00 AM
29psiHybrid
Jan 19, 2002 07:33 AM
