Window & Sunroof Auto-Up and Auto-Down
Old Apr 6, 2005 | 03:22 PM
Cashis Lee's Avatar
Default Window & Sunroof Auto-Up and Auto-Down
Sorry if this is a n00b question, but I've always wanted to know how to make my windows and sunroof close when I arm my alarm and possibly how to get them to all roll down and open when I disarm my alarm.
What parts would i need to buy and how hard would it be to hook up?
I have a DEI Viper 300 on a 92 Prelude Si.
Thanks for your help
Old Apr 6, 2005 | 03:32 PM
vitrox's Avatar
there are a few companies that make window rollup/down modules, you just need to find one. I hooked up a window roll up module the other day, all they need is 12volt,ground, and a negative trigger to tell them when to roll up. There are 4 other wires that go into the drivers door that hook directly to the window rollup wires.
the way I set this one up was when you pushed the 2nd accessory button on the remote the windows would roll up.
Old Apr 7, 2005 | 05:53 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: Window & Sunroof Auto-Up and Auto-Down (Cashis Lee)
DEI (Viper etc...) makes two parts:
530T which is two windows UP and DOWN
and
529T which is ONE window up and down (or sunroof open and close)
you can find them at your loal DEI dealer...
Old Apr 7, 2005 | 08:11 AM
Cashis Lee's Avatar
Thanks for the advice guys, do you know how hard it is to install the 530T?
Old Apr 7, 2005 | 10:23 AM
Default Re: (Cashis Lee)
not that hard, but if you doubt your ability, have a pro do it. it's worth it for peace of mind you know?
Old Apr 7, 2005 | 10:28 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cashis Lee &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the advice guys, do you know how hard it is to install the 530T?</TD></TR></TABLE>Easy as pie, if you have done it before, alittle harder if you are ok with car elec. and alarm systems. if your car has the auto down driver window you will have to install the 530t in the drivers door, no biggy, also the alarm has to have a ground out when armed, to trigger window roll up, any EXT. will trigger, venting, if triggered within 10sec of arming, [will roll windows down 1"] or all the way down if triggered when alarm disarmed. 94
Old Apr 7, 2005 | 12:20 PM
Mike M's Avatar
Founding Member
Default Re: (fcm)
I think I have a couple of 529 and 530T's if you need one.
529T can either put one window or sunroof up/down open/close with the touch of a switch. OR 2 Windows up or 2 windows down so you can use that one in 3 ways.
530T can put 2 windows up and down with the touch of the switch.
Also with both you can wire them to an output lead on your Alarms remote so that when you hold the button down it will open close your windows/sunroof. You can also wire it so that the Negative lead when the system is armed raises/closes the windows and then your extra output can be used to put the windows down. If you don't have an alarm you can use a "Channel Expander" which can add up to 6-8 channels to your current alarm by mixing key presses to activate each one, or you can use it by itself with a remote. Which I have both of extra.
Lets just say the stereo system I was once going to build was going to have a good bit of automation via remote
Old Apr 7, 2005 | 03:07 PM
fcm's Avatar
fcm
Old Fart
Default Re: (Mike M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M &raquo;</TD></TR><TR><TD CLASS="quote">I think I have a couple of 529 and 530T's if you need one.
Lets just say the stereo system I was once going to build was going to have a good bit of automation via remote </TD></TR></TABLE> Are you sure the 529t fully automates the windows, I though only the 530t did that. 94
Old Apr 7, 2005 | 07:50 PM
Mike M's Avatar
Founding Member
Default Re: (fcm)
Pretty sure, its just that it will only automate 1 window. (If memory serves me right)
Old Apr 7, 2005 | 07:53 PM
Default Re: (fcm)
529T
one window both ways or two windows one way
530T
two windows both ways or four windows one way
Old Apr 8, 2005 | 07:55 AM
fcm's Avatar
fcm
Old Fart
Default Re: (DAantagonist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist &raquo;</TD></TR><TR><TD CLASS="quote">529T
530T
two windows both ways or four windows one way</TD></TR></TABLE> From DEI themselfs the 529T will do 2 window up only, [or down only] the 530T will do 2 windows up and down, vent and automate the windows up and down.
There are 2 somewhat isolated relay circuits in each the units and if you isolate the triggers on the 529T you can use it to roll one window up and down, not so sure you can do that, [for 4 windows] on the 530T because of the automation circuit, but then anything is possible 94
Old Apr 8, 2005 | 08:32 AM
Cashis Lee's Avatar
Default Re: (fcm)
I guess I'll grab a 530T and find a wire-out diagram for my alarm and work at it.
So in order to get my sunroof to work with this, I would need a 530T for the two windows, and a 529T for the sunroof right?
Old Apr 8, 2005 | 09:02 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cashis Lee &raquo;</TD></TR><TR><TD CLASS="quote">I guess I'll grab a 530T and find a wire-out diagram for my alarm and work at it.
So in order to get my sunroof to work with this, I would need a 530T for the two windows, and a 529T for the sunroof right? </TD></TR></TABLE>Yes, but check with DEI they may make a sunroof modual also 94
H.
Jan 24, 2009 04:51 PM
gsrturbo-ek
Audio / Security / Video
May 19, 2008 08:01 AM
saanemon
11
Nov 24, 2006 12:53 PM
civicSlut
Apr 18, 2004 10:16 AM
jdmspoonitr
Oct 17, 2003 08:23 PM
