JDM LSD from M2B4 Tranny into M2Y4 USDM 5G Base Tranny?
Old Apr 6, 2005 | 01:18 PM
LUDEacris's Avatar
Default JDM LSD from M2B4 Tranny into M2Y4 USDM 5G Base Tranny?
Is this possible? and if it is what is required?
I know that you must us the M2B4 tranny case.
Is it possible to use the M2B4 tranny and LSD with the M2Y4 gear set?
Old Apr 6, 2005 | 01:23 PM
eMpAtHy's Avatar
Default Re: JDM LSD from M2B4 Tranny into M2Y4 USDM 5G Base Tranny? (LUDEacris)
does the m2y4 have shorter/closer gears or something?
Old Apr 6, 2005 | 01:28 PM
LUDEacris's Avatar
Default Re: JDM LSD from M2B4 Tranny into M2Y4 USDM 5G Base Tranny? (eMpAtHy)
I have a M2Y4 with good gears and syncros and I want to use the LSD from a M2B4. The M2B4 syncros might be bad so I don't want to use them.
Old Apr 6, 2005 | 07:33 PM
LUDEacris's Avatar
Can anyone help?
Old Apr 6, 2005 | 08:06 PM
jaxx4k's Avatar
from wat i understand n know they are not interchangable... or i should say not everything is a direct swap....so is no good
Old Apr 7, 2005 | 12:34 AM
eMpAtHy's Avatar
Default Re: JDM LSD from M2B4 Tranny into M2Y4 USDM 5G Base Tranny? (jaxx4k)
sell the m2y4 and pay for the synchro job for the m2b4
Old Apr 7, 2005 | 07:43 AM
2point6's Avatar
The M2B4 has a physically larger gear set than the M2Y4. As long as you change the entire gear set and the selector forks form the M2Y4 into the M2B4 casing you shouldn't have any issues.
Old Apr 20, 2005 | 05:01 PM
GirlNALude's Avatar
Default Re: JDM LSD from M2B4 Tranny into M2Y4 USDM 5G Base Tranny? (2point6)
if you wanna get rid of your m2y4 tranny and get a m2b4...im looking to buy a m2y4
Old Apr 21, 2005 | 12:18 PM
LUDEacris's Avatar
Default Re: JDM LSD from M2B4 Tranny into M2Y4 USDM 5G Base Tranny? (GirlNALude)
I'm actually looking at getting rid of the M2B4 tranny. It is currently not assembled and only requires bearings. I want to sell it for $300cdn....
hks_Racing
Apr 30, 2008 10:36 PM
pinoyk20
Dec 1, 2006 07:24 AM
bakes2913
Aug 24, 2005 07:40 PM
nomotor
Jun 24, 2004 10:56 AM
endlessdv
May 29, 2004 05:58 PM
