What is this plastic piece
Old Apr 6, 2005 | 12:23 PM
bosco500's Avatar
Default What is this plastic piece
Can someone please tell me what this piece is? It is hard plastic, not rubber, and has an o-ring. I think it goes somewhere in the head, but i'm not sure. Its off of a b18c.
Old Apr 6, 2005 | 12:32 PM
delacampos's Avatar
Default Re: What is this plastic piece (bosco500)
cam seal?
Old Apr 6, 2005 | 12:42 PM
bosco500's Avatar
Default Re: What is this plastic piece (delacampos)
The cam seal is rubber though, right? This is hard plastic with 4 black tabs on the bottom of it. Does it go over the cam seal or something?
Old Apr 6, 2005 | 12:59 PM
delacampos's Avatar
i think its the cam seal. i can't think of anywhere else it might go. yes, most of the time the cam seal is a thick rubber plug like that but i believe i've seen them like this as well. is the head disassembled now?
Old Apr 6, 2005 | 01:32 PM
dragit909's Avatar
yup cam seal
Old Apr 6, 2005 | 01:35 PM
DelSolDon's Avatar
the cam seal is much thicker and has two sides to it, not just one. it looks to me like it might be what covers the timing belt tensioner bolt or something else on the timing cover.
can you put a ruler next to it so we can tell how big it is?
Old Apr 6, 2005 | 01:53 PM
PreStaged12s's Avatar
Default Re: What is this plastic piece (DelSolDon)
its a cam seal that goes on the same side the distributor is on, OEM ones are cheap plastic that are usually held in by gasket sealer, that is definately a cam seal.
Old Apr 6, 2005 | 02:04 PM
bosco500's Avatar
Here are some more pics with a ruler. I dont *think* its a cam seal, but I could be wrong. The outside of it is worn, the inside is clean and oily. There is a small rubber o-ring around it. Thanks for all the replies!
Old Apr 6, 2005 | 03:08 PM
743power's Avatar
definitely exhaust cam seal.
Old Apr 6, 2005 | 03:30 PM
Big Teggie's Avatar
Default Re: What is this plastic piece (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">definitely exhaust cam seal.</TD></TR></TABLE>
No one else needs to guess. Thats the final and definite answer.
Old Apr 6, 2005 | 03:48 PM
bosco500's Avatar
Thanks a bunch
Old Apr 6, 2005 | 08:28 PM
rjay8604's Avatar
Default Re: (bosco500)
I believe the older b-series used a different style of cam seal. On my 1st gen b16 the cam seal doesn't have the "tangs" to be inserted while the cam holders are already in place. Mine was double sided and had to be put in before the cam bearing caps were torqued.
Old Apr 6, 2005 | 08:36 PM
B20vtec86crx's Avatar
like ALL 9 people said cam seal ....LOL i think we need more people to agree just to make sure it is..
Old Apr 6, 2005 | 08:38 PM
biassj's Avatar
Default Re: What is this plastic piece (Big Teggie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie &raquo;</TD></TR><TR><TD CLASS="quote">No one else needs to guess. Thats the final and definite answer. </TD></TR></TABLE>
Just put one in, it looked funny at first because it's so thin.
Old Apr 6, 2005 | 08:41 PM
743power's Avatar
Default Re: (rjay8604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">I believe the older b-series used a different style of cam seal. On my 1st gen b16 the cam seal doesn't have the "tangs" to be inserted while the cam holders are already in place. Mine was double sided and had to be put in before the cam bearing caps were torqued. </TD></TR></TABLE>
yea, I asked for a cam seal at the acura dealer for a gsr, and they gave me that kind. I don't know if certain motors and years used the different ones or what. . .
Old Apr 6, 2005 | 11:52 PM
bs-inc's Avatar
Default Re: (743power)
Since we're on the subject of cam seals, how do the oem cam seals compare to those aftermarket billet pieces like str?
Old Apr 7, 2005 | 12:04 AM
5STAR3's Avatar
would you like to use a life line
reminded me of millionaire.
Old Apr 7, 2005 | 01:08 PM
DelSolDon's Avatar
yep, thats how mine was on my 2nd gen b16. must be a b16 thang. they look just like the fancy billet ones, but just in rubber.
raverx3m
Feb 11, 2012 10:45 AM
Navy_Kyle
Nov 24, 2011 05:32 PM
endlssmystry
Jan 24, 2010 08:11 PM
DAintegraGSR
May 21, 2005 06:06 PM
MattyP
Oct 14, 2004 03:59 PM
