ITR`99 GearBox problem
Old Apr 6, 2005 | 12:02 PM
fUNk[LT]'s Avatar
Default ITR`99 GearBox problem
Hello Everyone
My English isn`t very good so I`ll try to explain everything in a short way. (I`ll try.. )
1. When Engine is cold it`s hard to shift all gears.
2. When Engine gets warmer shifting gets smoother but still need some effort to shift.
3. Sometimes second gears jums out.
4. When shifting on low revs i get short noise like sinchros but on hi revs everything`s ok.
5. Sometimes it`s very hard to down shift.
Checked my clutch, changed oil in gearbox, changed clutch disk bearing (don`t no how to say in english ).
Nothing helped still getting those problems that I metioned above
Old Apr 6, 2005 | 12:04 PM
Bbasso's Avatar
Default Re: ITR`99 GearBox problem (fUNk[LT])
Welcome to HT...
Sounds like you have syncro problems.
You will need to open the tranny and see
Enjoy your stay
Old Apr 6, 2005 | 12:09 PM
fUNk[LT]'s Avatar
Default Re: ITR`99 GearBox problem (Bbasso)
Thanx for such fast answer
G. I was affraid just of thinking about those sinchros... But how all 5 gears sinchros could be messed up..?
Old Apr 6, 2005 | 12:20 PM
Project X's Avatar
Are you using the right tranny fluid?
Old Apr 6, 2005 | 12:35 PM
fUNk[LT]'s Avatar
Default Re: (Project X)
I use Engine full synthetics oil for my tranny - Mobil Synt S 5W-40.
I also checke clutch fluid, slave and master cilinders are ok - no leaks.
Old Apr 6, 2005 | 12:39 PM
Bbasso's Avatar
Default Re: (fUNk[LT])
Even tho it might be going backwards I would dump what you have and use Honda's MTF.
Old Apr 6, 2005 | 12:41 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fUNk[LT &raquo;</TD></TR><TR><TD CLASS="quote">]I use Engine full synthetics oil for my tranny - Mobil Synt S 5W-40.
thats probably your problem right there...
in your most recent flush of the tranny fluid is this what you used?
if so, drain and replace with HONDA MTF
Old Apr 6, 2005 | 12:43 PM
fUNk[LT]'s Avatar
Default Re: (Bbasso)
My friend also has an ITR and he uses same oil for his tranny with no problems. I`m getting confused and my tranny is getting whorse day by day.
Old Apr 6, 2005 | 12:46 PM
Bbasso's Avatar
dump that oil and use MTF and report back
Old Apr 6, 2005 | 12:50 PM
BlueR's Avatar
and tell your friend to do the same
Old Apr 6, 2005 | 12:52 PM
fUNk[LT]'s Avatar
Default Re: (BlueR)
Ok I`ll try this tommorow. Thanx for replies
Oh one more question maybe its presure plate or smth?
Old Apr 6, 2005 | 12:56 PM
BlueR's Avatar
changing the fluid is cheaper and less time consuming than changing the pressure plate...so cross your fingers and hope that it works
Old Apr 7, 2005 | 03:08 AM
JLam's Avatar
check out the shaft and counter gears
Old Apr 8, 2005 | 08:08 AM
fUNk[LT]'s Avatar
Default Re: (BlueR)
Fluid changed no wonder I got the same problems. Now I`ll try to open my tranny...
Old Apr 8, 2005 | 11:50 AM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fUNk[LT &raquo;</TD></TR><TR><TD CLASS="quote">]Hello Everyone
C'mon you guys..... fluid isn't gonna fix that....
Opening up the transmission should have been the first thing to do when you noticed 2nd gear popping out. I'm certain you will find whatever you need to fix inside.
Here's something to help you get started:
https://honda-tech.com/zerothread?id=552502
in that thread it does mention the fluid might help....at least you tried that already
Old Apr 8, 2005 | 11:52 AM
BlueR's Avatar
Default Re: ITR`99 GearBox problem (RagingAngel)
was just trying to save him time and money
what harm could a fluid change do?
Old Apr 8, 2005 | 12:02 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">C'mon you guys..... fluid isn't gonna fix that.... </TD></TR></TABLE>
I know... that's why my first comment was:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Welcome to HT...
Enjoy your stay </TD></TR></TABLE>
Old Apr 8, 2005 | 12:07 PM
fUNk[LT]'s Avatar
Default Re: ITR`99 GearBox problem (BlueR)
Guys everything is allright thanks for your help I`ll try to rebuild my tranny and I hope it will be the end of all my problems... I really really hope so...
I will return in a week with good or bad results
Old Apr 8, 2005 | 12:08 PM
BlueR's Avatar
yes, report back with pictures of the tranny internals
Old Apr 8, 2005 | 12:35 PM
Chris N's Avatar
Your english is better than half the members who are american!
Old Apr 9, 2005 | 03:10 AM
fUNk[LT]'s Avatar
Default Re: ITR`99 GearBox problem (Chris N)
Thanx
aguill7
Dec 23, 2008 11:07 AM
graftuner34
Feb 28, 2007 12:56 PM
EJK20R
May 30, 2006 09:45 AM
N21
Feb 2, 2003 02:32 PM
ITR#203
Dec 28, 2002 08:26 AM
