Attention all 6th generation accords!
Old Apr 6, 2005 | 11:26 AM
Elvis1977's Avatar
Default Attention all 6th generation accords!
Exactly how long will the cv joints last on 98-02 Accords 4-cyl models? I have 132k and they still run perfect with no boot tears! Has any 6th generation Accord 4-cly. owner replaced their CV joint or axle?
Old Apr 6, 2005 | 12:45 PM
matt_in_sd's Avatar
Default Re: Attention all 6th generation accords! (Elvis1977)
Age and hot/dry weather have more to do with how long the boots will last then mileage. I have a '99 with 200k and they still look good.
Old Apr 6, 2005 | 01:00 PM
-Bionic-'s Avatar
Former Sponsor
Mine started clicking around 130K. Most likely because of the H22.
With a stock F23, they will last for a long time.
Old Apr 7, 2005 | 07:21 AM
Elvis1977's Avatar
Default Re: Attention all 6th generation accords! (matt_in_sd)
Is your car a 4-cyl? Man thats alot of miles so fast. Any other problems you have exprienced? Is you car an automatic with 200k??? Thanks.
Old Apr 7, 2005 | 10:21 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: Attention all 6th generation accords! (-Bionic-)
Yes. 4 Cyl.
BTW all F23 and H22 are straight fours.
It's manual.
No other problems that I am aware of in regards to the stock parts.
Old Apr 7, 2005 | 12:51 PM
matt_in_sd's Avatar
4 cyl, stick. When I bought it, it had 30k on it. The only problems I've had so far... bad alternator, and adjust the set screw for the idle. I started a thread here for the idle prob. The cat died, I will replace it next time I have to get a smog check. It burns a qt of oil in 3000 to 4000 miles. One reason I think it has done so well is that NO ONE touches my car. I do all the maintenance and repairs. My only beef with the car is that the arm rests suck.
Old Apr 7, 2005 | 02:43 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_in_sd &raquo;</TD></TR><TR><TD CLASS="quote"> 4 cyl, stick. When I bought it, it had 30k on it. The only problems I've had so far... bad alternator, and adjust the set screw for the idle. I started a thread here for the idle prob. The cat died, I will replace it next time I have to get a smog check. It burns a qt of oil in 3000 to 4000 miles. One reason I think it has done so well is that NO ONE touches my car. I do all the maintenance and repairs. My only beef with the car is that the arm rests suck. </TD></TR></TABLE>
Yeah. My alternarator went out around 120K miles.
Old Apr 7, 2005 | 04:47 PM
philadd's Avatar
My alternator went out at about 50k or so... There were 2 different alternators installed on Accords througout the years. One was actually made by GM, and I forgot the other manufacturer. I can't remember which at the moment, but one of the brands is known to fail, the other holds up fine.
The only other problems I've with my '99 were:
1. The crank pulley fell off while driving down the highway. The pulley was never touched before... The key weight (proper term?) apparently just broke apart. I've never heard of that happening before...
2. Front passenger door lock quit working. I was too lazy to ever get around to fixing it, and strangely enough, after 3 months of not working at all, it works perfectly again. I'm not complaining.
3. I had a pretty nasty vibration at idle for a while. But that's because I was still running the original distributor cap and rotor (140,000 miles). Finally replaced them and the car is nice and smooth once again.
Now at 145k miles, with no problems. CV joints are good, no cracks in the boots. Car has been lowered for the past 3 or so years.
Giant_Bean
May 2, 2010 02:22 AM
ib042129
Jul 23, 2008 02:22 PM
ConradRacing
Apr 10, 2007 06:21 PM
b20acura
Feb 23, 2007 12:24 PM
Elvis1977
Oct 21, 2003 07:04 AM
