Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
How much diff between 205 and 215/225 width tires on track/auto-x?
Old Jan 28, 2002 | 09:37 AM
uncleben's Avatar
Default How much diff between 205 and 215/225 width tires on track/auto-x?
I'm weighing out my wheel/tire options for this years season. A set of new Kosei K1's is gonna run me like nearly $550 for the 15x7's and nearly $650 for 16x7.5's. I'm always seeing people selling their used teg wheels for less than $200. They're of course going to be 15x6.
So two questions:
First, is an auto-x tire like the V700 or Victoracer really going to be that much better with the added size/contact of a 215 or 225 width tire, as opposed to the 205 width tire I'd probably have to stick with on a 15x6 wheel?
And second, is buying some used wheels (and probably not knowing their history) a Bad Idea for auto-x / track duty? Am I smarter to stick with some new wheels that are made for the stress, or is there no way in hell that I'm going to have to worry about stresses on some OE honda wheels, even used?
thanks, 'o masters of the craft!
Old Jan 28, 2002 | 09:42 AM
SPiFF's Avatar
Default Re: How much diff between 205 and 215/225 width tires on track/auto-x? (uncleben)
How much camber are you running? If you are running less then -2.0, then you won't be using 100% of even the 205s.
Depends on the price I guess. I am running a set of TSWs I got used. If I had to do it again .. I would have just paid the extra $300 or so and went with a new set of K1s.
Edit: I regret buying these TWSs becuase they are heavy as hell and don't want to stay torqued. If you can get a good set of 15x6 OE wheels for cheap, I would go for it.
[Modified by SPiFF, 1:44 PM 1/28/2002]
Old Jan 28, 2002 | 09:53 AM
uncleben's Avatar
Default Re: How much diff between 205 and 215/225 width tires on track/auto-x? (SPiFF)
Well, I just happen to have the alignment specs from the alignment I got 3 days ago (after i rolled my car on it's side)
Let's see - now I don't know the first thing about all these settings (FAQ anyone?)
There is min/max/nominal/actual listed, I'm assuming "actual" is the one that counts since it looks like all the others are the same from L/R wheel to wheel:
LF: -0.4
RF: -0.9
LR: -1.1
RR: -1.3
So in otherwords, to my first question, you'd say that the difference between a 205 and a 215/225 is going to be nominal performance gains?
Anyone have any reservations about using used OE wheels for racing? Safety wise? I could go get the K1's, but I'd just assume save a little money if it's nominal performance differences and no safety concerns.
[Modified by uncleben, 12:55 PM 1/28/2002]
Old Jan 28, 2002 | 09:59 AM
SPiFF's Avatar
LF: -0.4
RF: -0.9
LR: -1.1
RR: -1.3
Man .. how did you get more nagative camber in the rear?
Yea. With only around one degree negative camber, you will be riding on the outside edge of the tire most of the time anyway.
Old Jan 28, 2002 | 02:33 PM
uncleben's Avatar
Can I change that? I've heard of people doing an "autocross alignment," what all does that involve?
kriscabrera
Jan 25, 2012 06:01 PM
mrbkelley
May 22, 2011 07:08 PM
92blackg2
Feb 28, 2005 12:02 PM
Stewie
Dec 4, 2003 07:34 PM
uncleben
20
Feb 13, 2002 08:02 PM
