got my allign. now what?
Old Apr 6, 2005 | 05:34 AM
john d
Guest
Posts: n/a
Default got my allign. now what?
i remember seeing a thread saying, get an allignment and then come post to see what camber kit id need (suspension noob here so please help out)
Left Front- -1.19 Right Front- -1.61
Left Rear- -2.26 Right Rear- -2.63
Old Apr 6, 2005 | 05:44 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: got my allign. now what? (john d)
I am not good with aligment/camber.
Are you dropped? If so, how low?
IMHO, I don't even like camber kits. Some say it's good for the car, some say it's bad.
Bad-monkey should chime into this one.
PM him John.
Old Apr 6, 2005 | 05:48 AM
john d
Guest
Posts: n/a
Default Re: got my allign. now what? (Sticky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires &raquo;</TD></TR><TR><TD CLASS="quote">I am not good with aligment/camber.
PM him John.
oh i thought you were the suspension guru!
its dropped with h&r springs and kyb agx's
how can a camber kit be bad? isnt it better than leaving it at this negative camber?
Old Apr 6, 2005 | 06:02 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">
how can a camber kit be bad? isnt it better than leaving it at this negative camber?</TD></TR></TABLE>
No, I am far from a guru.
Since you're not dropped that low. You don't really need a camber kit. IIRC, negative camber is better for handling but wears out the tires faster if the camber is real bad.
I have heard of horror stories with camber kits. Then again, I've heard good ones too. It is really up to you.
Try running without a camber kit for a month or two. Check your tread wear. If it's bad, then get a camber kit.
I believe Shakes (Doug) has a brand new camber kit for sale. Unless he sold it already.
This is coming from a guy that ran Tein SS (finger gap all around) on his 5th gen w/ no alignment or camber kit. My tires were fine. (215/40/18)
Old Apr 6, 2005 | 06:05 AM
john d
Guest
Posts: n/a
damn, thanks for the info
Old Apr 6, 2005 | 06:07 AM
* B A N N E D *
No problemo.
Old Apr 6, 2005 | 06:13 AM
budget's Avatar
would having negative camber help or hurt with acceleration/traction?
i think you should just get a camber kit for the rear
Old Apr 6, 2005 | 06:19 AM
john d
Guest
Posts: n/a
Default Re: got my allign. now what? (ratboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ratboy &raquo;</TD></TR><TR><TD CLASS="quote">
i think you should just get a camber kit for the rear</TD></TR></TABLE>
want to know also...
anyone ever have expeience with obx camber kits?
Old Apr 6, 2005 | 06:27 AM
* B A N N E D *
Not sure. I don't see why it would. Maybe if you installed it wrong, it'll hurt something. lol
I did a search on "camber kit" under archives and found 2 pages of camber kit info. Try it out, until the suspension gurus get here.
Old Apr 6, 2005 | 06:41 AM
577HondaPrelude's Avatar
in theory neg camber will hurt grip for braking and acceleration, but help grip in turns (within a range). For example most road race Honda's run anywhere from -2 to -4.0 deg. chamber for best overall lap performance, however if you run this much chamber on a street car you will likely wear the inside of the tire faster than the outside.
I would just leave your car the way it is for now and if you start to wear the insides of the tires real fast then worry about getting a chamber kit. The main thing that will wear your tires is the toe so just make sure that is near zero.
Old Apr 6, 2005 | 06:45 AM
* B A N N E D *
Default Re: got my allign. now what? (577HondaPrelude)
That is what I'm saying. There is no need for a camber kit unless you have major tread wear. You don't want to spend money on something you don't need.
john d
Guest
Posts: n/a
the toe on all for is between 0-.31 so im just gunna get the camber kit in the rear, bc the 2 rear tires are sitting sideways almost
Old Apr 6, 2005 | 10:04 AM
bad-monkey's Avatar
crap i just typed out a long as reply and lost it.
i would get a rear camber kit, since the -2.63 is a little excessive in the rear for a daily driven car. even for a race car the -2.63 is a little too much negative camber in the rear. i would set it at around -1 degree in the rear.
577 is right about handling/traction and camber. in theory straight line traction would be best with 0 camber, however suspensions being what they are, when you're launching the front springs decompress as the weight shifts to the rear, and the suspension geometry in the front changes the camber to become more and more positive (and the rear becomes more negative). in a FF car, you'd probably want some static negative camber up front so that the camber is closer to zero when the car is laying down most of its power. on a race car that turns, you'd want tons of negative camber. -2.5 degrees F, -3.0 degrees F, and -1.5 or -1.0 degrees rear. when turning, camber is one of your best friends.
on camber wear: i personally don't think camber wear is a big deal at all. camber combined with severe toe-in/toe-out will kill tires, but that's mostly the toe setting. a couple degrees of negative camber with zero toe won't significantly affect the life of your tires. i've been running my tires for the past 15,000 miles with -2.0 all around and haven't noticed any camber wear. the tread is about 1/4" deep all the way across the tire.
Old Apr 6, 2005 | 10:06 AM
* B A N N E D *
Default Re: (bad-monkey)
The pros have chimed in.
Old Apr 6, 2005 | 03:30 PM
john d
Guest
Posts: n/a
Default Re: (Sticky Tires)
thanks sticky and bad monkey. which is better progress or obx?
Old Apr 7, 2005 | 05:00 AM
* B A N N E D *
Default Re: (john d)
I would say progress. IMO, OBX is too APC'ish for me. They haven't been around long enough.
Do not forget to thank 577. He has been around here longer and have helped a whole lot.
Old Apr 7, 2005 | 08:56 AM
bad-monkey's Avatar
progress makes good stuff. i'd go w/ progress or SPC.
Old Apr 7, 2005 | 09:25 AM
Greyout's Avatar
slight negative camber in the front is ideal for traction off the line.
Old Apr 7, 2005 | 06:23 PM
john d
Guest
Posts: n/a
Default Re: (Greyout)
i think im gunna go with the obx camber kit progress is only adjustable up to 1.75 i need it to atleast do 2
Old Apr 7, 2005 | 07:26 PM
john d
Guest
Posts: n/a
JDM_EjONE
Suspension & Brakes
10
Aug 17, 2006 07:36 PM
crxsteve
Jul 19, 2006 08:49 AM
9crx1
Jun 16, 2004 11:10 AM
Wazup
63
Feb 7, 2004 06:54 PM
Accord2K1
Jul 11, 2003 06:00 PM
