hazards and turn signals dont work
hey i have a 90 ls with a b17a swap. After the swap i got my car back and realized my signals, hazards and horn doesnt work. I was curious if there is a relay or a main fuse that controls all of these and where it is located. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyfastteg »</TD></TR><TR><TD CLASS="quote">hey i have a 90 ls with a b17a swap. After the swap i got my car back and realized my signals, hazards and horn doesnt work. I was curious if there is a relay or a main fuse that controls all of these and where it is located. thanks</TD></TR></TABLE>
sounds like the relay crapped out (for the hazards and signals). check the horn fuse. both of these should be located somewhere around the driver kickpanel area.
Check your turn signal fluid. It has to be drained when the motor is taken out. Might have forgot to refill it. I'd only get the honda fluid though, since it's made for it. p/n 4071 at the dealer.
No but really though, it's prolly a fuse. I have a '94 and its a fuse, so i'd assume the '90 did too. Assume. Car's manual, or a Hanes would tell you. Or better check the cover for the fuse box.
k20eklipse
26
Jul 12, 2010 08:55 PM
