ctr pistons n gsr rods in b16a
Old Apr 5, 2005 | 08:16 PM
turboJDMeg6's Avatar
Default ctr pistons n gsr rods in b16a
can i put ctr pistons and gsr rods into my 90 b16a? do i have to do nething to modify the drop in of these or no?
also if running ctr cams with toda cam gears, should i upgrade my valve springs to either itr or skunk2? lmk thanks
Old Apr 5, 2005 | 10:59 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: ctr pistons n gsr rods in b16a (91b16ef9)
Not trying to be a dick, but are you crazy, the gsr rods are way to long. Use your stock rods, have a mm shaved off each side of the small end and have your pistons pressed on. Yes it would be a good idea to upgrade your valvesprings, itr's would be decent, stay away fron skunk 2. Omnipower, or rocket motorsports spring and retainer packages would be a much better choice. Good luck
Old Apr 5, 2005 | 11:43 PM
Default Re: ctr pistons n gsr rods in b16a (PURPLETERROR)
ah i see i see, thank you for the info..u say have a mm shaved off each side. do u mean 1mm? sorry im new to this but yah, experimenting is learning
Old Apr 6, 2005 | 08:51 AM
EG6 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteczone &raquo;</TD></TR><TR><TD CLASS="quote">
no they are not! if they are,then honda shud have stamp pr3 on the gsr rod instead of p72!! to you for getting the wrong fact!</TD></TR></TABLE>
I stand corrected..........
Old Apr 6, 2005 | 08:56 AM
vteczone's Avatar
Default Re: ctr pistons n gsr rods in b16a (EG6 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 SiR &raquo;</TD></TR><TR><TD CLASS="quote">
They are the same length. </TD></TR></TABLE>
GSR rod 137.9mm
B16a rod 134.36mm
Old Apr 6, 2005 | 09:11 AM
EG6 SiR's Avatar
Default Re: ctr pistons n gsr rods in b16a (vteczone)
GSR rod 137.9mm
B16a rod 134.36mm
My bad guys , after some searching I came accross the right info. Now instead of making this a totally useless thread, I will give a good link that has a chart with all the different specs. Here you go http://raceseek.com/honda_specs.htm
Old Apr 6, 2005 | 09:49 AM
wolve's Avatar
hey that's a usefull link, but is'nt the stroke of a b16a 77.4 mm equal to 3.096 inches??
this link says 3.047 wich will equal 76.175 mm . that don't seem right does it???
because of this the r/s ratio is off too, it's around 1.7 and with b20 rods and special pistons it will be 1.74 and something. damn near 1.75 (ideal to alot people).
this site tells you it's already 1.74, wich is totally off. first check the specs on this site if you wanna use it, just my .02
Old Apr 6, 2005 | 02:07 PM
EG6 SiR's Avatar
Default Re: ctr pistons n gsr rods in b16a (wolve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wolve &raquo;</TD></TR><TR><TD CLASS="quote">hey that's a usefull link, but is'nt the stroke of a b16a 77.4 mm equal to 3.096 inches??
this site tells you it's already 1.74, wich is totally off. first check the specs on this site if you wanna use it, just my .02 </TD></TR></TABLE>
Well according to the conversion calculater from Mr. Jeeves at ask.com,
3.047=77.3938.
I think maybe you got your math wrong or something, heres the link to the conversion calculater, its at the top of the page right next to Mr. Jeeves himself. Hope this helps clear some things up http://web.ask.com/web?q=conve...src=8
Old Apr 6, 2005 | 03:37 PM
Big Teggie's Avatar
GSR rods also have a narrower big end than B16 rods.
ZCSp0ngeR
10
Mar 2, 2009 08:48 PM
HondaTrac
Jan 11, 2006 09:44 PM
johnzm
Aug 8, 2003 07:45 AM
Spids5
May 24, 2003 04:20 PM
