8mm Arp rod bolts in a LS
Old Apr 5, 2005 | 07:15 PM
the DA in HONDA's Avatar
Default 8mm Arp rod bolts in a LS
when putting the 8mm rod bolts into ls rods do you have to take it to a machine shop and get the rod drilled out or do you just replace the factory bolts
Old Apr 5, 2005 | 07:32 PM
reactiondc2's Avatar
Default Re: 8mm Arp rod bolts in a LS (the DA in HONDA)
they will just replace the stock rod bolts...alot of people will tell you to get the rod resized after you install them but i didnt and my lsvtec saw 9200+ for 10k reliable miles till i sold it
Old Apr 5, 2005 | 08:59 PM
Default Re: 8mm Arp rod bolts in a LS (reactiondc2)
anyone else have an opinion
Old Apr 6, 2005 | 06:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the DA in HONDA &raquo;</TD></TR><TR><TD CLASS="quote">anyone else have an opinion
Old Apr 7, 2005 | 06:34 AM
chameleon's Avatar
only a machine shop can replace the bolts, dont think you can do this yourself, they have to be pressed in and all that so please let a machine shop handle it, that has experience with honda work.
Old Apr 7, 2005 | 12:59 PM
AllMotorDA9's Avatar
Default Re: 8mm Arp rod bolts in a LS (chameleon)
When i was building my b20 I was short on time so i couldnt pull out my pistons and have the arp rod bolts pressed in by a shop so i just did it myself. All is fine, it sees 7700 daily.
Im not telling not to have them pressed in, cause you should if you have the time and money. But my experience of doing it myself went smoothly.
Old Apr 7, 2005 | 02:23 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: 8mm Arp rod bolts in a LS (AllMotorDA9)
the old ones come out easy.. i took mine out and put them in myself.. if you have the confidence, do it yourself ...if not and have the money get it done by a shop
Old Apr 7, 2005 | 07:06 PM
Default Re: 8mm Arp rod bolts in a LS (turbofienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">only a machine shop can replace the bolts, dont think you can do this yourself, they have to be pressed in and all that so please let a machine shop handle it, that has experience with honda work.</TD></TR></TABLE>wrong it is easy to do at home...did mine myself never had a problem
Old Jun 1, 2005 | 01:56 PM
mycrx7's Avatar
let me know how u did it yourself easy bro im working on a lsvtec right now its its prob the best choice to put them in, do i need to take out the pistons and rods?
Old Jun 1, 2005 | 03:03 PM
DonF's Avatar
Default Re: 8mm Arp rod bolts in a LS (mycrx7)
Because they have a ditt. torque spec and crush factor , you should have the big end remachined after the install with the bolts torqued to the proper spec. But then doing it right does cost about $30.00- $40.00 bucks.
Old Jun 1, 2005 | 03:31 PM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycrx7 &raquo;</TD></TR><TR><TD CLASS="quote">let me know how u did it yourself easy bro im working on a lsvtec right now its its prob the best choice to put them in, do i need to take out the pistons and rods?</TD></TR></TABLE>yes of course u need to take out the pistons and rods..do it right take it to the machine shop have them install it , properly reshape rod, etc....dont halfass on a build to save a couple bucks..because most likely it will come back and bite yah...for a few hundred bucks at the least
Old Jun 1, 2005 | 03:59 PM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reactiondc2 &raquo;</TD></TR><TR><TD CLASS="quote">wrong it is easy to do at home...did mine myself never had a problem</TD></TR></TABLE>
can you post up exactly how you did it????
Old Jun 1, 2005 | 05:18 PM
JCushing's Avatar
Default Re: 8mm Arp rod bolts in a LS (Mr.RHTuner)
second that request
Old Jun 1, 2005 | 05:45 PM
Yambor's Avatar
Default Re: 8mm Arp rod bolts in a LS (JCushing)
https://honda-tech.com/zerothread?id=1262236
go to this thread, and scroll down to see pics of a properly resized rod...
Old Jan 12, 2006 | 09:40 PM
the.hamburglar's Avatar
Default Re: 8mm Arp rod bolts in a LS (JH4DC4-2GSR)
how do you resize a rod?
Old Jan 12, 2006 | 09:56 PM
budsmachine's Avatar
Default Re: 8mm Arp rod bolts in a LS (the.hamburglar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">how do you resize a rod?</TD></TR></TABLE>
you cut around .001 off the mating surfaces of the cap and rod. After reinstalling the bolts and torqued together the big end is now around .002 smaller in diameter. We then stick it in a machine with hone stones and bring the diameter back to the original specs, perfectly round +\- .0001
Old Jan 22, 2006 | 10:21 PM
Fiveplusjuan's Avatar
what kind of power can the ls rods handle with the arp rod bolts??
Old Jan 23, 2006 | 05:53 AM
Natural Aspirations's Avatar
about 5000 watts
Old Jan 23, 2006 | 06:29 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the DA in HONDA &raquo;</TD></TR><TR><TD CLASS="quote">when putting the 8mm rod bolts into ls rods do you have to take it to a machine shop and get the rod drilled out or do you just replace the factory bolts
you get the machinist to check bore roundness again after torquing new bolts. they sometimes need to line bore it.
greg
Old Jan 23, 2006 | 03:43 PM
Default Re: 8mm Arp rod bolts in a LS (crixzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crixzc &raquo;</TD></TR><TR><TD CLASS="quote">about 5000 watts</TD></TR></TABLE>
wow, thats alot of power dickbag.
Old Jan 23, 2006 | 07:48 PM
dont ask stupid questions if you dont like my anwsers
Old Jan 23, 2006 | 10:41 PM
hybrid_vtec's Avatar
Default Re: (crixzc)
You can do it yourself(change the rod bolts), but I just let the machine shop do it, b/c i had the rods resized. Many ppl do not resize the rods, but I recommend it.
Old Jan 24, 2006 | 05:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crixzc &raquo;</TD></TR><TR><TD CLASS="quote">dont ask stupid questions if you dont like my anwsers
sorry i am not a master import drag racer engine builder like you...............I think it is a legit question to ask.
2ndchirp
Jun 20, 2024 01:15 PM
Wazup
Mar 31, 2005 02:58 PM
SiBuddy00
Feb 28, 2005 01:06 PM
turbohf
May 11, 2004 06:30 AM
FastFoot
Sep 28, 2002 12:09 AM
