B20 swap requirments.. what else do i need??
Old Apr 5, 2005 | 04:05 PM
SuperImport's Avatar
Default B20 swap requirments.. what else do i need??
Okay.. I have the GE v-tec conversion kit and i was wondering if I needed a new water and oil pump and what kind would be best to go.. if not getting one straight from Honda.. and if I need to do any additional work with cooling the pistons (je 11:5) because obviously there are no squirters. i was told that with after market pistons over heating shouldn't be a problem. My first B20 guys so I need a little help.. Thanks.. peace
Old Apr 7, 2005 | 02:03 PM
Default Re: B20 swap requirments.. what else do i need?? (SuperImport)
bump
Old Apr 7, 2005 | 04:42 PM
MI4$DC5's Avatar
im not sure but i think you would be good with GSR waterpump and oil pump, well thats what im going to use on my b20vtec
Old Apr 10, 2005 | 03:08 PM
Default Re: (MI4DC2)
Do you think I would def need a new fuel pump and timing belt or could I use my stock pump and belt??
Old Apr 11, 2005 | 03:34 AM
Default Re: (SuperImport)
bumppp
Old Apr 11, 2005 | 03:39 AM
Grand's Avatar
you need a 94-01 gsr/type r oil and water pump then you have to use a 94-01 gsr timing belt
you should be fine with a stock fuel pump
ps good luck with your buld keep me posted
Old Apr 11, 2005 | 11:17 AM
Default Re: (LG_R32)
thanks for the info and i def will keep ya posted
beaneg6
Mar 10, 2009 04:08 AM
Dr.Octagon
Jun 12, 2006 07:42 AM
RTW DC2R
Jul 2, 2004 07:07 AM
88B20CRX
Apr 17, 2003 05:23 PM
gsrhatch22
Jul 3, 2002 04:22 AM
