what ecu to use for this swap
I have a ef hatch and now dropping in a 1993 d16z6 motor.I need to know what computer that i can use to put in to bolt up to my wire harness and also to engage v-tec
what else can i do to avoid putting in a obd1 harness and comp.so the v-tech could engage and the wire harness to bolt up perfect.
dont do a RPM activated switch. get the conversion harness from OBD-0 to OBD-1 and run a P28 ECU w a 4 wire O2 Sensor and the OBD-1 dizzy. Trust me its worth it. Otherwise the motor will never run to its potential..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beyond Imagination »</TD></TR><TR><TD CLASS="quote">i would SUGGEST converting to obd1 and using p28. there are also other options.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXVTEC69 »</TD></TR><TR><TD CLASS="quote">dont do a RPM activated switch. get the conversion harness from OBD-0 to OBD-1 and run a P28 ECU w a 4 wire O2 Sensor and the OBD-1 dizzy. Trust me its worth it. Otherwise the motor will never run to its potential.. </TD></TR></TABLE>
Just do the conversion. You will be much happier with the results. Using an rpm switch activates VTEC but it does not change the fuel and timing maps. When the correct ecu is used the maps change when VTEC compensating for the increased air entering the engine.
92integraVTECgsr
Mar 30, 2010 05:58 AM
slammedz6ef
Dec 31, 2007 04:13 AM
