jdm b18c valve adjustment same as usdm b18c1??
Old Apr 5, 2005 | 11:57 AM
AlxSiR7's Avatar
Default jdm b18c valve adjustment same as usdm b18c1??
just adjusted my valves TWICE and they are still tapping!! the only thing i can think of is the valve lash specs are different for the JDM B18C, since I followed the instruction from http://www.c-speedracing.com/h...t.php for the USDM B18C1. any suggestions??
Old Apr 5, 2005 | 12:21 PM
KingFish's Avatar
Default Re: jdm b18c valve adjustment same as usdm b18c1?? (AlxSiR7)
You are not removing the camshaft holder plate are you? Do you not have a manual? The clearances you stated will work for the JDM b18c. From the web site you linked you can get all the manual information and even print it out. I would recommend doing this if you have not already. You must make sure that the piston is at TDC (top dead center) for the valves you are adjusting. There are four valves for each cylinder, so you need to adjust each of them while the corresponding piston is at TDC. Start with the number one cylinder. The order will be like this 1-2-3-4. When looking at your engine the no.1 cylinder is on the driver side. They are arranged like this (passenger side 4-3-2-1 driver side). Other than these few suggestions maybe you need to find someone who has done it before. Make sure you're adjusting the valves to .007 not .07 because there is a big difference. I am guessing you know that the intake and exhaust valves are adjusted differently. Intake-.006"-.007" and the exhaust- .007"-.008".
I don't mean to belittle you by telling you about the piston and firing order I hope you already know these things just trying to help out. Good luck man!!
Old Apr 5, 2005 | 01:12 PM
AlxSiR7's Avatar
Default Re: jdm b18c valve adjustment same as usdm b18c1?? (KingFish)
yeah man.. i already know what i'm doing. they are just a little loud still.. maybe it's the injectors too.. i'm not sure. thanks for responding though.
Old Apr 5, 2005 | 01:27 PM
KingFish's Avatar
Hope you find the problem. Glad to hear that you know what you are doing because some people just don't know.
Old Apr 5, 2005 | 01:38 PM
95lstegman's Avatar
i adjust my valves every few thousand miles. the first time i did it though, i still heard a lot of noise, so i did it again, still noise. i put a screwdriver to one of my injectors to hear the ticking, and it was LOUD! i was just expecting a soft tick-tick-tick but what i got was BAM! in the ear. it's probably your injectors. mine are rediculously loud.
Old Apr 5, 2005 | 02:36 PM
AlxSiR7's Avatar
Default Re: jdm b18c valve adjustment same as usdm b18c1?? (95lstegman)
i guess thats all it is.. i'm going to ask my friend next time i see him and see what he thinks since he works on hondas all the time.
Old Apr 5, 2005 | 05:00 PM
Lu DC2's Avatar
Maybe your clearences aren't right yet! It should idle very smoothly and quietly once done right!
tigasTT
Dec 15, 2015 02:46 PM
1gEF-8
Jul 15, 2011 06:18 PM
gsrjdmb18c
Dec 1, 2009 09:54 PM
Hilary_duff
Feb 23, 2005 08:43 AM
HT Chaplain
Aug 14, 2003 05:05 AM
