Just picked up this block for my build. Just had to bring it back to live
Old Apr 5, 2005 | 11:33 AM
NotUrAvgSi's Avatar
Default Just picked up this block for my build. Had to bring it back to life
When i picked it up
This is after hours and hours of scrubbing
And then some buffing made it like this
Thanks for looking
Modified by NotUrAvgSi at 8:52 PM 4/5/2005
Modified by NotUrAvgSi at 10:31 PM 4/5/2005
Modified by NotUrAvgSi at 10:32 PM 4/5/2005
Old Apr 5, 2005 | 11:36 AM
NSTY Z33's Avatar
Dissasemble it, and have the machine shop clean it.
Old Apr 5, 2005 | 11:49 AM
tha-Gr8-one8's Avatar
Default Re: Just picked up this block for my build. had to bring it back to live (NotUrAvgSi)
man that must of took you hourS
Old Apr 5, 2005 | 11:50 AM
NotUrAvgSi's Avatar
oh it was fun i tell you
Old Apr 5, 2005 | 11:52 AM
Team Underground Teg's Avatar
Default Re: (NotUrAvgSi)
Big difference!
Old Apr 5, 2005 | 11:58 AM
staticrex's Avatar
Default Re: (Team Underground Teg)
What a pain but looks awesome now. good job
Old Apr 5, 2005 | 12:19 PM
AnToNy's Avatar
Good job. Looks hella better.
Old Apr 5, 2005 | 12:21 PM
darkcvc's Avatar
Blue Sedan Crew
Default Re: (staticrex)
so fresh and so clean
Old Apr 5, 2005 | 12:22 PM
NotUrAvgSi's Avatar
thanks for all the positive feedback
slammed_93_hatch's Avatar
Default Re: Just picked up this block for my build. had to bring it back to live (jaedaSC)
pressure washer with some castrol super clean mixed in. then some high temp aluminum paint gets it like that rather trouble free. Only thing that wont take care of is rust and corrosion, for that use metal etch and a wire brush
Old Apr 5, 2005 | 12:24 PM
smnowell's Avatar
Default Re: (darkcvc)
I bet your arms are ******' ripped now. I wouldn't be surprised if that took you well over 6 hours of solid work to get the block that clean if you did that all by hand with no parts washer or anything like that.
Old Apr 5, 2005 | 12:55 PM
TedR719's Avatar
Default Re: (smnowell)
why not hot tank the bish?
Old Apr 5, 2005 | 01:16 PM
4genaccordfreak's Avatar
better protect it with something HI TEMP.. or all that hard work will look like **** once that aluminum oxidizes!! go buy some Duplicolor hi temp clear coat! i think its 500F i know most of the colors come in 1200F but im not sure about the clear.. do it up and make it STAY clean and shiny!
Old Apr 5, 2005 | 01:18 PM
EJ1 wilcox's Avatar
Default Re: (TedR719)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TedR719 &raquo;</TD></TR><TR><TD CLASS="quote">why not hot tank the bish?</TD></TR></TABLE>
This would have been easier...
But nice work Looks 100000x better!
Old Apr 5, 2005 | 01:28 PM
NotUrAvgSi's Avatar
yea it was pain in the *** and i know i could have done it lot easier like beat blasted or hot tanked. But i was bored so i just did it all by hand. a tooth brush some weird *** chemicall that my dad brought home i think it was like a industrial degreaser and after all I took a dremel to it.
Old Apr 5, 2005 | 02:51 PM
patastinky's Avatar
Default Re: (4genaccordfreak)
Old Apr 5, 2005 | 02:54 PM
prayludin's Avatar
Default Re: (patastinky)
looks real clean
Old Apr 5, 2005 | 03:09 PM
NotUrAvgSi's Avatar
Default Re: Just picked up this block for my build. Had to bring it back to life (NotUrAvgSi)
to h-t lovin
Old Apr 5, 2005 | 03:26 PM
Chase's Avatar
clean clean clean....i like it. Im gonna be re-freshing a gsr block soon for my build. Im not goin by hand like you though, prolly pressure wash/hot tank it, then scuff it up and paint it Aluminum color with lots of clear.
Old Apr 5, 2005 | 03:44 PM
Local Tuner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team Underground Teg &raquo;</TD></TR><TR><TD CLASS="quote">Big difference! </TD></TR></TABLE>
Old Apr 5, 2005 | 04:07 PM
DnB TeK's Avatar
sweet
Old Apr 5, 2005 | 04:18 PM
743power's Avatar
Default Re: Just picked up this block for my build. Had to bring it back to life (DnB TeK)
all that work and its still assembled. . .
the things people do when they are bored. . .
Old Apr 5, 2005 | 04:39 PM
MugenJibz's Avatar
Old Apr 5, 2005 | 05:04 PM
B2FiNiTY's Avatar
Default Re: Just picked up this block for my build. Had to bring it back to life (MugenJibz)
What was the process involved and what materials did you use?
Old Apr 5, 2005 | 05:28 PM
NotUrAvgSi's Avatar
Default Re: Just picked up this block for my build. Had to bring it back to life (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">What was the process involved and what materials did you use? </TD></TR></TABLE>
I used a industrial grade deagreaser that my dad brought home in a gallon bucket but im sure there alot of other good degreasers that will work just as good. If you have a pressure washer that will help out big time. I didnt. I found using a tooth brush worked out very well to get into spots. When i got pretty much everything off i took a drill with a soft wire brush and cleand up a bit more with that. The rest was all done with a dremmel.
calib17a
Jul 19, 2011 06:35 PM
JDM_COUPE
May 2, 2007 10:33 PM
sittin on GOLD
Mar 21, 2006 07:57 PM
edo
23
May 20, 2005 05:32 PM
B18CXr
Apr 14, 2003 02:15 PM
