April 05 Specials @ Wired Speedlab!! Precision, Blox, ACT, Exedy and more
Honda-Tech April 05 Specials
Honda-Tech,
Here are your specials for April 05. Take advantage of getting nothing but the best products at a great price! Please follow the links or click on the product image for all of your Honda-Tech pricing. Please be sure to click the actual line item of the product you wish to purchase as the advertised pricing is not Honda-Tech pricing by far.
ACT XACT Prolite Flywheel
Most Stock flywheels are heavy cast iron and are designed for optimum drivability by storing some of the engine’s power in the form of inertia. Light flywheels provide significantly improved engine response and acceleration by compromising drivability. M
ACT XACT Streetlite Flywheel
BLOX Performance Intake Manifold
The BLOX one-piece cast aluminum intake manifold will greatly improve your engine's overall flow characteristics compared to the factory unit.
By using the latest in casting technology, the overall weight of each unit is dramatically reduced which makes the BLOX intake manifold the lightest in the industry. Each application has been designed using a larger plenum and longer intake runners. Each is then tuned for peak power at high RPM.
BLOX intake manifolds are ideal for naturally-aspirated and forced induction applications. All factory sensors and throttle body may be utilized, while the recessed bolt holes make for a simpler installation.
BLOX Tuner Series Camshafts
BLOX high performance camshafts offer the enthusiast increased horsepower and torque over the entire RPM range, through various designs and custom profiles.
All camshafts start off as raw castings sourced from OEM materials. Each is then manufactured using the latest design software and chill-casting technologies. All camshafts are CNC-ground to precise and exacting tolerances and specifications.
BLOX currently offers different levels of performance through its Tuner and Competition Series. Custom (semi-blank) camshaft cores are also available for racers and engine builders that require blank cores in order to grind to their own profiles.
BLOX Turbo Exhaust Manifold
The BLOX turbo exhaust manifold is constructed from high silicone ductile iron, using the latest casting technologies. Each cast exhaust manifold features a centralized wastegate bung between the #2 and #3 cylinders, to greatly improve the boost response, and mates to T3/T4 turbocharger. Also, the 3.5mm thick intake runners dramatically reduce the overall weight of the manifold, making the BLOX manifold superior over its competitors. BLOX turbo exhaust manifolds come with a lifetime warranty against cracks and are available for Honda B-series engines.
BLOX Universal Muffler
DRAG Turbo Kit
Exedy Stage 2 Thick Cerametallic Clutch
Exedy Stage 2 Thin Cerametallic Clutch
GReddy Type RS Blow Off Valve
Created to be the most reliable blow off valve system available, the Type-RS's state-of-the-art design allows for greater performance in a compact size. Improved response and increased pressure are achieved through carefully selected spring rates and a large 40mm valve. The real unique feature of the Type-RS blow off valve is the CNC machined 8 discharge ports that draw in the surrounding air to amplify the blow-off sound. The Type-RS is compatible with the standard GReddy Blow-off Valve flanges.
GReddy Type RS features:
-High capacity performance, and a compact frame
Hondata Intake Manifold Heatshield
Hondata K-Pro Programmable ECU
Hondata K100 System
Hondata K20 Reflash
Hondata P28 Chipped ECU (OBD2A)
Hondata P28 Chipped ECU (OBD2B)
Hondata S100 Base System
Hondata S100 Base System w/ Boost
Hondata S200 Base System
Hondata S200 Base System with Boost
<strong>Now Includes Datalogging AND 3 step rev limiter at No Extra Charge!</strong>
Invidia G200 Titanium Tip Exhaust
Each G200 Exhaust features a super-strength titanium tip with an expanded tip size to maximize exhaust air flow. On top of performance, the colored look of the titanium tip gives the G200 Exhaust the aggressive look.
Invidia N1 Cat Back Exhaust System
PeakBoost Turbo Downpipe
Fully tig welded 3” downpipe with Flex section and fully tig welded thick wall dumptube for use with the 38mm wastegate, stainless steel 02 bung included.
PeakBoost Turbo Intercooler Piping
PeakBoost Turbo Kit
This is a complete bolt on kit for the Honda B-Series motor in a 92-00 Honda Civic or 94-01 Acura Integra (Acura Integra must use civic style radiator). the kit includes:
PeakBoost Stainless Steel equal length exhaust manifold made of 304L 8 gauge stainless (Lifetime warranty)
Garrett T3/TO4E turbocharger
Tial 38mm wastegate
PWR 24x6x3.5 Intercooler (2.5" inlet and outlet)mounts directly to factory bumper support
Tial blow off valve
12inch "Slimline" pusher radiator fan
Fully TIG welded complete 3 peice 2.5" charge piping (no modifications necessary)
3inch downpipe with stainless flex section and wastegate dumptube.
Stainless oil feed (-4) and oil drain (-10) lines (featuring earls fittings.)
Weldless oil drain line
All necessary couplings
Strong T-Bolt hose clamps
All necessary gaskets
not for use with a/c
ex: Stock B18C Civic 330whp/230ftlbs @ 10lbs Stock B18C Civic 270whp/195ftlbs @ 6lbs On average this kit makes ~20whp per lb of boost...!
$765.00
PeakBoost Turbo Manifold
1.5 304: Stainless Steel Equal Length Runners. Mild Steel Flanges, 1/8th thick wall, 4-1 Merge Collector, T3 Turbine Flange, 35/38mm wastegate flange.
<strong> LIFETIME Warranty Against Manufacturing Defects.</strong>
$103.00
Precision 1000cc Low Impedence Injector
Precision Front Mount Intercooler
RC Engineering Saturated Injector
While RC Engineering injectors dominate import drag racing and SCCA World Challenge road racing, RC Engineering’s handiwork is not limited to just the race track. The most discriminating enthusiasts of high-performance street vehicles use a set of higher-f
RPS Turbo Clutch Street Disc Max
RPS Turbo Clutch Street Disc Sport
TEIN HTECH Lowering Springs
TEIN HIGH.TECH springs utilize the latest spring and material technology to optimize comfort, performance and quality. The line is produced with Vanadium, which is stong, lightweight and has properties to retain more spring stroke. HIGH.TECH springs are
TEIN STECH Lowering Springs
TiAL 38mm High Pressure Wastegate
TiAL 38mm Wastegate
TiAL 44mm Wastegate
TiAL 46mm High Pressure Wastegate
TiAL 46mm Wastegate
TiAL Blow Off Valve
Walbro 190lph Fuel Pump Kit
Walbro 190 liter per hour, High Pressure inline fuel pump for fuel injected vehicles.
Walbro 255lph Fuel Pump Kit
Fuel-injected vehicles that utilize an in-line fuel pump may benefit from the Walbro 255 liter per hour in-line fuel pump.
Pricing can be found here as well http://www.wiredspeed.com/stor...April
If you have any questions please feel free to pm or email me directly.
Ricky
Modified by WIRED RICKY at 4:41 PM 4/6/2005
Honda-Tech,
DRAG Turbo Kit
Hondata K100 System
Hondata K20 Reflash
PeakBoost Turbo Kit
Tial 38mm wastegate
Tial blow off valve
$765.00
$103.00
TiAL 38mm Wastegate
TiAL 44mm Wastegate
TiAL 46mm Wastegate
TiAL Blow Off Valve
Ricky
EVERYONE has a pm.
I am always on aim. That is usually the easiest way to get ahold of me. Also, sometimes we get over 40 pms at a time when logging on. Not all of them go thru, if your missed, send it again or call us. We dont avoid anyone.
Ricky
Ricky
Also there was a problem with the server wed thru friday last week. The links should all be working now.
If you get an error page when trying to go to the site, just hit refresh. If it still doesnt come up then its a problem on our end. We try getting it up as quick as possible.
Sorry for any mishaps from the site being down.
Ricky
Ricky
Plenty more of these in stock. We have another load coming in so lets get these rolling.
I will be returning to the office on Monday May 1st.
Any sales or order inquiries please call us at 1800 wired 80.
Kyle and Eric are both available for any questions you may have.
For anyone that wants to paypal us.
paypal@wiredspeed.com
Just put what its for on the notes.
Thanks
Ricky
Thanks
Ricky
