Putting on new rotors
Old Apr 5, 2005 | 08:49 AM
Anthrolude's Avatar
Default Putting on new rotors
Im just getting ready to put on some oem sized brembo drilled/slotted rotors on my prelude. Doesnt seem to0 tough.... Just wondering before I jump in if you guys had any tips, tricks, anything to watch for?
Old Apr 5, 2005 | 08:56 AM
The Phil's Avatar
Default Re: Putting on new rotors (tourhcky)
Bleed the brakes when you're done. Use a brake spring compressor for the rear rotors, it beats using a big flat screwdriver. Use an impact driver to remove the screws holding the rotors on, or else you'll hate yourself for it.
Old Apr 5, 2005 | 09:06 AM
Anthrolude's Avatar
Default Re: Putting on new rotors (xthephilx)
awesome, thanks
Old Apr 5, 2005 | 09:33 AM
SKDRCR's Avatar
You don't have to bleed the brakes unless you mess with the lines
or the fluid system itself.
Old Apr 5, 2005 | 09:41 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">Bleed the brakes when you're done. Use a brake spring compressor for the rear rotors, it beats using a big flat screwdriver. Use an impact driver to remove the screws holding the rotors on, or else you'll hate yourself for it.</TD></TR></TABLE>
What do you mean by a brake spring compressor?
The rear claiper piston has to be turned to go in.
I don't recall the rotors having any screws holding them on either,
the lug nuts do that.
Wipe off the new rotors with brake cleaner before installing them.
Old Apr 5, 2005 | 09:42 AM
bad-monkey's Avatar
Default Re: Putting on new rotors (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean by a brake spring compressor?
Wipe off the new rotors with brake cleaner before installing them.</TD></TR></TABLE>
the rotors have screws in em. they're a total ******* pain in the *** too.
next time i'm changing rotors i'm leaving them off. they're just there to keep the rotor from falling off when the wheel is off.
Old Apr 5, 2005 | 10:04 AM
junbb1's Avatar
i am under a real strong impression that brembo doesnt make 4th gen vtec slotted/drilled rotors. only for the si.
they are available for the fifth gen though.
Old Apr 5, 2005 | 10:15 AM
leonard1818's Avatar
Default Re: Putting on new rotors (junbb1)
HMMM I am going to do and Si---&gt; Vtec brake upgrade in my 93Si soon and i was under the impression that 5th gen brakes were the same as 4th gen vtec... I guess not but something i read made me think that...
Also, i thought u only had to bleed the brakes if you were putting on new calipers which I have yet to call honda to see if i need new calipers for the Si----&gt;vtec but i think so. Anyway I was planning on bleeding my brakes but for this situation i think its not necessary.
Old Apr 5, 2005 | 10:28 AM
Monkey Fing a Coconut's Avatar
Default Re: Putting on new rotors (leonard1818)
yeah bleeding the brakes is not necessary, and an impact screwdriver works magic on those screws
Old Apr 5, 2005 | 10:49 AM
The Phil's Avatar
Default Re: Putting on new rotors (twistedbydezign)
After I replaced my rotors, my brakes needed to be bled. That's why I threw that up there.
Its this thing that turns the rear caliper piston while compressing it. Makes it easier to do. I've never used the damn thing though...I just have a really big flat screwdriver that I use to turn the rear piston.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">I don't recall the rotors having any screws holding them on either,
the lug nuts do that.</TD></TR></TABLE>
Usually people just leave them off. They just make changing rotors a pain in the *** anyway.
Old Apr 5, 2005 | 05:27 PM
five-0's Avatar
You could probably replace the "PITA" rotor screws with allen heads or torx. That would make it less of a pain in the long run. I was gonna do this, but I guess it's just as easy to grab the impact driver. A little anti-seize probably wouldn't hurt either.
BTW... Is is possible to turn slotted rotors? Just curious.
Old Apr 5, 2005 | 05:28 PM
The Phil's Avatar
Default Re: Putting on new rotors (five-0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by five-0 &raquo;</TD></TR><TR><TD CLASS="quote">BTW... Is is possible to turn slotted rotors? Just curious.</TD></TR></TABLE>
Should be, as they usually aren't REALLY warped, just warped by a few mm.
Old Apr 5, 2005 | 05:51 PM
92hondalude's Avatar
dont you have to remove the big axel nut to get the rotors off also?
Old Apr 5, 2005 | 05:53 PM
five-0's Avatar
Default Re: Putting on new rotors (92hondalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">dont you have to remove the big axel nut to get the rotors off also?</TD></TR></TABLE>
No sir.
Old Apr 5, 2005 | 09:40 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by five-0 &raquo;</TD></TR><TR><TD CLASS="quote">You could probably replace the "PITA" rotor screws with allen heads or torx. </TD></TR></TABLE>
good idea
Old Apr 6, 2005 | 06:57 AM
577HondaPrelude's Avatar
Default Re: Putting on new rotors (PrettyLude)
I took those screws and trashed them years ago, they are not really needed.
datssoled
17
Jan 6, 2007 04:50 PM
EM1 Loi
Jul 15, 2005 12:24 PM
VWTECH1
Dec 14, 2003 02:54 PM
chad
Jul 11, 2003 08:54 PM
prjctCIVIC
Jul 9, 2002 06:54 PM
