Suspension & Brakes Theory, alignment, spring rates....
Race this weekend... easy way to increase rear springrates?
Old Apr 5, 2005 | 07:33 AM
.nate's Avatar
Default Race this weekend... easy way to increase rear springrates?
I'm assembling my new motor like a madman this week trying to get everyting in the car and tuned by Sunday so I can make it to a BOTI race. One thing I don't have time to get is stiffer rear springs.
Can anyone suggest a way to stiffen the rear springs cheaply? I only need it for one day on the race track.
TIA...
Old Apr 5, 2005 | 07:43 AM
AutoXer's Avatar
Default Re: Race this weekend... easy way to increase rear springrates? (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">
TIA...</TD></TR></TABLE>
Get rear springs with higher rates?
There's no magical way to get higher spring rates without getting a higher rate spring.
Old Apr 5, 2005 | 07:54 AM
fireant's Avatar
Default Re: Race this weekend... easy way to increase rear springrates? (EX_AutoXer)
rear toe out.
Old Apr 5, 2005 | 07:59 AM
.nate's Avatar
This is a drag race not a autox. BTW...
Anyway, I guess I was hoping that there was somethingI could get to effectively stop the spring from compressing as much.
I realize that getting springs with higher rates is the ideal thing to do, but I do not have the time nor the money at this point to do that...
Old Apr 5, 2005 | 08:10 AM
Tyson's Avatar
Default Re: (.nate)
stick blocks in between your springs.
disclaimer: i never tried this, and not recommending it. just an idea, it for sure will stiffen your springs, but not sure if it would be beneficial or not damage anything because i have no experience.
Old Apr 5, 2005 | 08:31 AM
raene's Avatar
You could try limiting straps on the front suspension instead? And get the crossmember polyurethane inserts to avoid wheelhop... maybe easier than trying to increase rear rates.
Old Apr 5, 2005 | 09:40 AM
bad-monkey's Avatar
i thought i read about some sort of poly insert for doing exactly what you're asking. search this forum, the thread is fairly recent and has a link in it.
Old Apr 5, 2005 | 10:43 AM
.nate's Avatar
Tyson and bad-monkey: This is what I'm looking for, thanks. I'll search around for that thread.
raene: I made a set of limit straps for the racecar, but it just streched the cables I used. I believe I will need to run a set of those nylon 4000lb straps a few people are selling on here. Comes back to the time and money thing. I'm already stretching it trying to finish my block assy (it's at the machine shop right now getting a hone and balancing the bottomend) and getting it back together, the car dialed in and tuned by sunday for this race.
Redsun
Suspension & Brakes
May 10, 2006 04:20 PM
Timmy!
Suspension & Brakes
Apr 19, 2006 07:23 AM
Dyzee
May 1, 2004 05:35 PM
NINJASPY
Sep 19, 2003 11:56 PM
C1V1C
Mar 10, 2003 09:46 AM
