Sneak Peak: Half of a 2.0L project complete...
Winter/spring project getting close to completion. More details and pics to follow this month.
Bottom end specs:
-B18C1 Block
-GE Sleeves
-8.5cc Dome Wiseco IB Pistons
-Type R Crank
-Polished crankcase
-Carillo Rods
-Moroso Pan
-Cometic 30k MLS Gasket
With the pistons 18k in the hole (tall block!) it CC'd at 13.2:1
Going to give the new Skunk cams a try.
Bottom end specs:
-B18C1 Block
-GE Sleeves
-Type R Crank
-Polished crankcase
-Carillo Rods
-Moroso Pan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97L-esVeeTeg »</TD></TR><TR><TD CLASS="quote">damn teasers!
Whats this going to be used for RR?
Just a fun EG street car.
Ok this needs to stop!!! Two friends of mine in the Street Mod class just built high comp motors. How in the hell am I going to keep up to guys this year!!!!! NOT FAIR!!!
Nice build up Clayton!!!
Give me a call when you go to dyno tune that monster. I need to take care of some topend tuning on my motor.
Give me a call when you go to dyno tune that monster. I need to take care of some topend tuning on my motor. Trending Topics
I see the fittings for an ENDYN catch can too, good thing you did that with the motor out of the car, trying to get those installed in car is a bitch. So your gonna try the Skunk Pro 1s? I have 13:1 cr on Skunk stage3's, havent tuned it yet though, hopefully soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreStaged12s »</TD></TR><TR><TD CLASS="quote">I see the fittings for an ENDYN catch can too, good thing you did that with the motor out of the car, trying to get those installed in car is a bitch. So your gonna try the Skunk Pro 1s? I have 13:1 cr on Skunk stage3's, havent tuned it yet though, hopefully soon.</TD></TR></TABLE>
I have a question about that ENDYN catch can........I see the two plugs that come with the kit but what do you use to plug the hole that the stock breather box fits into? I have seen a pick that looked like a freeze plug was used to block off the hole but how does that freeze plug stay in place? The hole is not threaded or anything. Does the freeze plug expand when heated so you end up with an interference fit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">Freeze plugs are a press fit. You can get them at any decent auto parts store. The threaded adapters come off of the H22 engine.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadtownSi »</TD></TR><TR><TD CLASS="quote"> I have a question about that ENDYN catch can........I see the two plugs that come with the kit but what do you use to plug the hole that the stock breather box fits into? I have seen a pick that looked like a freeze plug was used to block off the hole but how does that freeze plug stay in place? The hole is not threaded or anything. Does the freeze plug expand when heated so you end up with an interference fit?</TD></TR></TABLE>
The freeze plug comes with the kit, the instructions just say to use some hondabond and press it in which is easy to do. By the way Madtown, I love that avatar, nice job
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommy69 »</TD></TR><TR><TD CLASS="quote">Whats the bore on that motor?</TD></TR></TABLE>
84.5mm
84.5mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ausmith »</TD></TR><TR><TD CLASS="quote">
Just a fun EG street car.</TD></TR></TABLE>
That will be a POE-TANT lil' street car.
Thanks for posting the part numbers Clayton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV »</TD></TR><TR><TD CLASS="quote">i think we used a 34mm freeze plug in my GSR, dont quote me on that.
34.5mm Freeze plug with a 'lil Honda Bond.
34.5mm Freeze plug with a 'lil Honda Bond.</TD></TR></TABLE>
A rubber expansion plug will also work if anyone is wondering.
