91 hatch front LCA..............pop pop pop!!!!!!!!
about a week ago i put my front LCA's w/ poly bushings in my hatch
ever since then there has been a popping noise coming from where the LCA bolts to the subframe when i turn going under 5mph
i heard about not having the right sleeves in the bushings but i took them off the car and put the bolt thru and it looked to be correct
i put grease all over where the LCA bolts the the subframe and the noise went awayso i know thats the problem area , is this normal or are my control arms going to fall off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannabe_si »</TD></TR><TR><TD CLASS="quote">did you torque the bolts down when the suspension was loaded or when the suspension was unloaded?</TD></TR></TABLE>
Dont think that matters if they are poly bushings.
quest4boost
10
Nov 29, 2006 05:56 PM
PiXeL
Mar 23, 2006 10:11 AM
